| 0004696 | FreeCAD | Bug | public | 2021-07-02 16:50 | 2022-01-25 18:26 |
| Reporter | mcgiwer | Assigned To | chennes | ||
| Platform | amd64 | OS | Debian | OS Version | 10 |
| Summary | 0004696: Problems with startup from command line (attached logs) | ||||
| Description | When I attempt to start a fresh (just downloaded from the freecad.org website) FreeCAD from the console and add an " & " char at the end (to run it in background), I get a following error message thrown out in the terminal window: | ||||
| Steps To Reproduce | Attempt to start FreeCAD from the console, adding after the command a space and the & character | ||||
| Additional Information | For security reasons, I had replaced in the attached debug log the path to the home folder | ||||
| Tags | 0.19 | ||||
[UPDATE] I had discovered that the issue was caused because xcb couldn't become loaded. I got able to fix this by typing in the console following command: |
[UPDATE] Note: The path where freeCAD is placed has been truncated for security reasons After updating python to the version 3.9, it stopped to work with following errors: ` Python path configuration: PYTHONHOME = '/usr/lib/python3.9' (set manually) PYTHONPATH = (not set) program name = 'bin/freecad' isolated = 0 environment = 1 user site = 1 import site = 1 sys._base_executable = 'bin/freecad' sys.base_prefix = '/usr' sys.base_exec_prefix = '/usr' sys.executable = 'bin/freecad' sys.prefix = '/usr' sys.exec_prefix = '/usr' sys.path = [ '/usr/lib/python38.zip', '/usr/lib/python3.8', '/usr/lib/python3.8/lib-dynload', ] Fatal Python error: init_fs_encoding: failed to get the Python codec of the filesystem encoding Python runtime state: core initialized ModuleNotFoundError: No module named 'encodings' Current thread 0x00007fd8b4507800 (most recent call first): <no Python frame> ` Additionally, I don't know why the "PYTHONPATH" variable is displayed as not beeing set, even if it's has been exported. Enviromental informations:
Hopefully it helps |
It looks like this is two different bugs, and that the first one has been resolved -- is that correct? |
@mcgiwer Your original bug report appears to have been resolved and was related to your system configuration. My read is that your later post here is a totally separate bug, so I plan to close this one shortly. If that is not the case, please let me know. |
@mcgiwer ping |
@Kunda1 pong ;-p |
@chennes The both bugs are related to each other and I'm not sure why they are becomming thrown out. To add it, this issue has appeared suddenly because in not long time earlier, the FreeCAD was working correcly. I hope it's only a temporary problem |
This ticket has been migrated to GitHub as issue 6237. |
| 2021-07-02 16:50 | mcgiwer | New Issue | |
| 2021-07-02 16:50 | mcgiwer | Tag Attached: 0.19 | |
| 2021-07-14 18:28 | mcgiwer | Note Added: 0015735 | |
| 2021-07-18 19:30 | mcgiwer | Note Added: 0015737 | |
| 2021-07-18 19:33 | mcgiwer | Note Edited: 0015737 | |
| 2021-07-18 20:44 | mcgiwer | Note Edited: 0015737 | |
| 2021-08-11 17:20 | chennes | Note Added: 0015806 | |
| 2021-08-11 17:20 | chennes | Assigned To | => chennes |
| 2021-08-11 17:20 | chennes | Status | new => feedback |
| 2021-12-29 03:23 | chennes | Severity | block => minor |
| 2021-12-29 03:26 | chennes | Note Added: 0016136 | |
| 2021-12-29 03:26 | chennes | Priority | high => normal |
| 2022-01-25 18:17 | Kunda1 | Note Added: 0016301 | |
| 2022-01-25 18:23 | mcgiwer | Note Added: 0016304 | |
| 2022-01-25 18:23 | mcgiwer | Status | feedback => assigned |
| 2022-01-25 18:26 | mcgiwer | Note Added: 0016305 |
