| 0000472 | FreeCAD | Bug | public | 2011-11-04 09:24 | 2011-11-04 18:16 |
| Summary | 0000472: Arch Icons | ||||
| Description | Windows XP SP3. ATI Graphics Card The display of icons in the Arch module is not correct. See Attached capture. Nicolas (Sous Windows XP SP3. Carte Graphique ATI L'affichage des icones dans l'atelier Arch ne se fait pas correctement. Voir la capture Ci-joint. Nicolas) | ||||
2011-11-04 09:24
Qt's SVG module has some problems in older versions because it only supports SVG Tiny. In newer versions it seems that it has better support but is probably still not perfect. Two solutions: 1. create a PNG from every SVG file and use this 2. use QtWebkit to render better icons from a SVG Today I have implemented (but not activated yet) solution 2). So far this works great. |
Fixed in rev 5090. Using Webkit to render SVG is now activated on Windows. |
| 2011-11-04 09:24 | unauthenticated | New Issue | |
| 2011-11-04 09:24 | unauthenticated | File Added: 01.png | |
| 2011-11-04 17:56 | wmayer | Note Added: 0001229 | |
| 2011-11-04 18:16 | wmayer | Note Added: 0001231 | |
| 2011-11-04 18:16 | wmayer | Status | new => closed |
| 2011-11-04 18:16 | wmayer | Resolution | open => fixed |
| 2011-11-04 18:16 | wmayer | Fixed in Version | => 0.12 |
