| 0004741 | TechDraw | Bug | public | 2021-09-07 07:21 | 2022-01-02 16:31 |
| Reporter | AtD | Assigned To | wandererfan | ||
| Fixed in Version | 0.20 | ||||
| Summary | 0004741: Broken File After Using Landmark Dimension in TechDraw | ||||
| Description | Please see following discussion: https://forum.freecadweb.org/viewtopic.php?f=22&t=61879 I report this as 0.20 as chrisb reproduced it with 0.20. I myself only tested in two 0.19 versions. After adding a landmark dimension between Draft-Point-Objects inside a TechDraw sheet, the file is easily broken by just opening and closing a non-related sketch in the model. User openBrain identified it as an error in TechDraw. | ||||
| Steps To Reproduce | Please see forum discussion for steps to reproduce. There is also the file to test the behavior. It occurs in a less disturbing manner, when using Part Point objects instead of Draft Points, however the file is still broken and throws an Access violation error. | ||||
| FreeCAD Information | My FreeCAD Version (0.19): OS: Windows 10 (10.0) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.24212 (Git) Build type: Release Branch: master Hash: 3d227cf7179c00e57f2733f947b4b1b0368d219a Python version: 3.8.8 Qt version: 5.12.5 Coin version: 4.0.0 OCC version: 7.4.0 Locale: German/Germany (de_DE) chrisb's FreeCAD Version (0.20): OS: macOS 10.16 Word size of FreeCAD: 64-bit Version: 0.20.25566 (Git) Build type: Release Branch: master Hash: 8c361dd3fc83840a911da950a845eb9f9342a0b6 Python version: 3.9.6 Qt version: 5.12.9 Coin version: 4.0.0 OCC version: 7.5.2 Locale: C/Default (C) | ||||
| 2021-09-07 07:21 | AtD | New Issue | |
| 2021-09-07 07:57 | AtD | Tag Attached: TechDraw | |
| 2021-09-08 08:20 | openBrain | Tag Detached: TechDraw | |
| 2021-09-08 08:20 | openBrain | Status | new => confirmed |
| 2021-12-07 13:51 | wmayer | Note Added: 0016065 | |
| 2022-01-02 16:31 | wandererfan | Assigned To | => wandererfan |
| 2022-01-02 16:31 | wandererfan | Status | confirmed => closed |
| 2022-01-02 16:31 | wandererfan | Resolution | open => fixed |
| 2022-01-02 16:31 | wandererfan | Fixed in Version | => 0.20 |
| 2022-01-02 16:31 | wandererfan | Note Added: 0016176 |
