| 0000475 | FreeCAD | Bug | public | 2011-11-08 18:52 | 2011-11-09 07:21 |
| Reporter | msynth | Assigned To | |||
| Summary | 0000475: "File was not written with this version of the topology" | ||||
| Description | Although it is possible to use FreeCAD console to do the FreeCAD operations (such as Booleans), but only after opening the created file with the GUI of FreeCAD and clicking on the created objects the file will be updated and you can save the files. Otherwise the saved files will be empty Asciis. | ||||
| Additional Information | To see the error, you can do as follows: 1. run the following Macro: import FreeCAD import Part FreeCAD.open("~/L1.FCStd") App.ActiveDocument=App.getDocument("L1") Gui.ActiveDocument=Gui.getDocument("L1") App.getDocument("L1").removeObject("Fillet") App.getDocument("L1").removeObject("Fusion") FreeCAD.getDocument("L1").getObject("Box").Height = 9.00 FreeCAD.getDocument("L1").getObject("Box001").Height = 9.00 FreeCAD.getDocument("L1").getObject("Box002").Height = 9.00 FreeCAD.getDocument("L1").getObject("Box002").Width = 60.00 App.activeDocument().addObject("Part::MultiFuse","Fusion") App.activeDocument().Fusion.Shapes = [App.activeDocument().Box002,App.activeDocument().Box001,App.activeDocument().Box] FreeCAD.ActiveDocument.addObject("Part::Fillet","Fillet") FreeCAD.ActiveDocument.Fillet.Base = FreeCAD.ActiveDocument.Fusion __fillets__ = [] __fillets__.append((20,3.00,3.00)) FreeCAD.ActiveDocument.Fillet.Edges = __fillets__ del __fillets__ FreeCADGui.ActiveDocument.Fusion.Visibility = False App.getDocument("L1").FileName = "~/L2.FCStd" App.getDocument("L1").Label = "L2" App.getDocument("L1").save() 2. Unzip the L2.FCStd 3. You will see that Partshape3 and 4 are empty. I have attached both L1 and L2. | ||||
2011-11-08 18:52
According to http://forum.freecadweb.org/viewtopic.php?f=10&t=1866&sid=9094f6cbd847d946976bd49b58561847 a App.activeDocument().recompute() is missing before saving. |
| 2011-11-08 18:52 | msynth | New Issue | |
| 2011-11-08 18:52 | msynth | File Added: FreeCAD files L1 and L2.zip | |
| 2011-11-09 07:21 | wmayer | Note Added: 0001267 | |
| 2011-11-09 07:21 | wmayer | Status | new => closed |
| 2011-11-09 07:21 | wmayer | Resolution | open => no change required |
| 2011-11-09 07:21 | wmayer | Fixed in Version | => 0.12 |
