| 0000476 | FreeCAD | Bug | public | 2011-11-09 10:03 | 2011-11-18 18:14 |
| Reporter | bodzio38 | Assigned To | yorik | ||
| Summary | 0000476: DXF problem | ||||
| Description | Problem with export to DXF. Bad arc when angle is greater than 180 degrees. | ||||
2011-11-09 10:03
I believe this is fixed by Dan Falck's alterations committed in r5135. If still an issue, please reopen |
No in r5149 is still bad. Please view new files bug.dxf and freecad project. |
2011-11-18 15:32
Ok, I'll have a look at it. |
Ok hopefully now this is fixed (rev 5150). As far as i tested arc direction in dxf output is always correct. Reopen if you find other counter-cases... |
| 2011-11-09 10:03 | bodzio38 | New Issue | |
| 2011-11-09 10:03 | bodzio38 | File Added: dxf_bug.zip | |
| 2011-11-09 11:13 | wmayer | Status | new => assigned |
| 2011-11-09 11:13 | wmayer | Assigned To | => yorik |
| 2011-11-17 13:42 | yorik | Note Added: 0001302 | |
| 2011-11-17 13:42 | yorik | Status | assigned => closed |
| 2011-11-17 13:42 | yorik | Resolution | open => fixed |
| 2011-11-17 13:42 | yorik | Fixed in Version | => 0.12 |
| 2011-11-18 15:31 | bodzio38 | Note Added: 0001309 | |
| 2011-11-18 15:31 | bodzio38 | Status | closed => feedback |
| 2011-11-18 15:31 | bodzio38 | Resolution | fixed => reopened |
| 2011-11-18 15:32 | bodzio38 | File Added: bug.zip | |
| 2011-11-18 16:08 | yorik | Note Added: 0001310 | |
| 2011-11-18 18:14 | yorik | Note Added: 0001311 | |
| 2011-11-18 18:14 | yorik | Status | feedback => closed |
| 2011-11-18 18:14 | yorik | Resolution | reopened => fixed |
