| 0004767 | FreeCAD | Bug | public | 2021-10-17 20:08 | 2021-10-17 20:08 |
| Reporter | BruceL | Assigned To | |||
| Summary | 0004767: Pocket using SubShapeBinder does not occur on orthogonal axis. | ||||
| Description | Forum Post When making pockets with sub-shapebinders, FreeCAD insists on pocketing along the z-axis. | ||||
| Steps To Reproduce | 1. Open the attached SM-PLB03A case file. 2. make "SLIDE_IN" the active body 3. select the "vent_binder" subshapebinder in "SLIDE_IN" 4. pocket the "vent_binder" 5. observe that the pocket appears to be along the z axis as it appears in the section below the "vent binder" instead of along the y axis where I would expect it. 6. note that the "thread_holes_2" pocket, which is also based on a subshapebinder from "MAIN_CASE" works fine (but it's along the z-axis) | ||||
| FreeCAD Information | OS: Debian GNU/Linux bookworm/sid (GNOME/gnome) Word size of FreeCAD: 64-bit Version: 0.20.25997 (Git) AppImage Build type: Release Branch: master Hash: 77b198048a63f1e9ca15eef64c8042d599a14cf3 Python version: 3.9.7 Qt version: 5.12.9 Coin version: 4.0.0 OCC version: 7.5.2 Locale: English/Canada (en_CA) | ||||
