| 0004773 | FreeCAD | Bug | public | 2021-10-28 01:27 | 2021-11-16 17:54 |
| Reporter | sceptre357 | Assigned To | chennes | ||
| Priority | urgent | Severity | major | Reproducibility | always |
| Platform | Linux | OS | Debian 11 | OS Version | Debian 11 - KDE |
| Summary | 0004773: Please Help!! no longer can delete or insert rows/columns in spredsheets | ||||
| Description | Right clicking on a row or column has no effect in spreadsheet, no menu appears. i've searched everywhere in the menus and all buttons, there is now no way to insert or remove a row, i cant work. Also, with more complex models, single spreadsheet changes take FOREVER to recompute. So in the event i need to make multiple changes, i set the document to skip recomputes, then i make all the changes, then manually recompute using F5 or right click and recompute. Now its not functioning anymore. Nothing happens after pressing F5! no changes are updated. you must not skip recomputes or nothing gets updated, something is definitely wrong. these two issues have brought my work productivity to nearly nothing. PLEASE HELP, i really would appreciate a quick resolution. | ||||
| FreeCAD Information | OS: Debian GNU/Linux 11 (bullseye) (KDE/plasma) Word size of FreeCAD: 64-bit Version: 0.20.26155 (Git) AppImage Build type: Release Branch: master Hash: 0926a4148bcff11249fd4f56bc30256102ffe105 Python version: 3.9.7 Qt version: 5.12.9 Coin version: 4.0.0 OCC version: 7.5.3 Locale: English/Philippines (en_PH) | ||||
also, clicking a cell and pressing Alt+A to enter tag alias name and pressing enter doesnt work anymore. Now its even more tedious a process than it was before. Please consider making an option to use the previous Column as the automatic alias for the next column. for example, i layout my spreadsheet like so Column 1 Column 2 Column 3 Alias Name measurement description it would be a huge time saver to allow column 1 to act as the alias name for data in column 2. its a huge pain in the neck to set the alias for each row, double entering the column 1 name anyway. please really consider an option for this, its super annoying. Spreadsheets should be as efficient and easy to use as possible. |
Your feature requests are going to get lost here when combined with this bug report: make sure you post about them in the forum. Regarding the bug report, I can reproduce. I suspect it was merged in 2d10f5cac but I have not run a bisect yet to verify. |
The bug reported here (the missing context menus) should be fixed by ba2459cddc14f60d459909406789d0471f0030f6 |
Tested. Can confirm problem is fixed. |
| 2021-10-28 01:27 | sceptre357 | New Issue | |
| 2021-10-28 02:43 | sceptre357 | Note Added: 0015999 | |
| 2021-10-28 02:44 | sceptre357 | Note Edited: 0015999 | |
| 2021-11-01 04:01 | chennes | Note Added: 0016003 | |
| 2021-11-01 04:39 | chennes | Note Added: 0016004 | |
| 2021-11-01 04:40 | chennes | Assigned To | => chennes |
| 2021-11-01 04:40 | chennes | Status | new => resolved |
| 2021-11-01 04:40 | chennes | Resolution | open => fixed |
| 2021-11-16 17:54 | openBrain | Status | resolved => closed |
| 2021-11-16 17:54 | openBrain | Note Added: 0016034 |
