| 0004774 | Sketcher | Bug | public | 2021-10-29 22:26 | 2021-10-30 20:35 |
| Reporter | garya | Assigned To | wmayer | ||
| Platform | PC | OS | FreeBSD | OS Version | 11.4-RELEASE |
| Fixed in Version | 0.20 | ||||
| Summary | 0004774: Datum plane or line is not available in sketch in another body via binder | ||||
| Description | If you create a Datum line or Datum plane in one body, then create a shape binder for that datum in a second body, the object referenced by the shape binder cannot be selected for constraints in a sketch. See https://forum.freecadweb.org/viewtopic.php?p=539227#p539227 (The first part of the thread is not really relevant to this bug; only from the reference on) | ||||
| Steps To Reproduce | Open the file DatumShapeBinder.FCStd Double-click Body001 to activate it. Part Design WB Create new sketch in XY Plane (Note the ShapeBinder plane is valid for creating a new sketch) Note that neither the datum line nor the datum plane show up, and therefore cannot have an external geometry link made to them for constraint purposes. Click on the Model tab. Click on Body to select it. Space to make it visible Note that the plane and line show up. Click on External Geometrty tool Click on line and plane; you'll get a beep, as they are still unselectable. | ||||
| FreeCAD Information | OS: FreeBSD 11.4-RELEASE-p6 (XFCE/xfce) Word size of FreeCAD: 64-bit Version: 0.20.master Build type: Release Python version: 3.7.9 Qt version: 5.15.2 Coin version: 4.0.0 OCC version: 7.5.0 Locale: C/Default (C) | ||||
| 2021-10-29 22:26 | garya | New Issue | |
| 2021-10-29 22:26 | garya | File Added: DatumShapeBinder.FCStd | |
| 2021-10-30 20:35 | wmayer | Assigned To | => wmayer |
| 2021-10-30 20:35 | wmayer | Status | new => closed |
| 2021-10-30 20:35 | wmayer | Resolution | open => fixed |
| 2021-10-30 20:35 | wmayer | Fixed in Version | => 0.20 |
| 2021-10-30 20:35 | wmayer | Note Added: 0016002 |
