| 0004776 | FreeCAD | Bug | public | 2021-11-02 05:55 | 2021-11-07 22:34 |
| Reporter | sceptre357 | Assigned To | chennes | ||
| Platform | Linux | OS | Debian 11 - KDE | OS Version | kernel 5.10 |
| Fixed in Version | 0.20 | ||||
| Summary | 0004776: Cannot Manually Recompute Anymore if "Skip Recomputes" is Enabled | ||||
| Description | if you enable "Skip Recomputes" for the open document, any changes you make in a spreadsheet do not take effect after a manual recompute. It doesnt matter if you press F5 or use the mouse and click recompute, it still doesn't work. What is quite strange is that it does take a normal amount of time to recompute but after the model is not updated, it remains the same. if you disable "skip recomputes" and make changes to your spreadsheets, the does model get updated. | ||||
| FreeCAD Information | OS: Debian GNU/Linux 11 (bullseye) (KDE/plasma) Word size of FreeCAD: 64-bit Version: 0.20.26238 AppImage Build type: Release Branch: (HEAD detached at 237229c) Hash: 237229c3fc8df1ddede445d3495a0ac640d63e4f Python version: 3.9.7 Qt version: 5.12.9 Coin version: 4.0.0 OCC version: 7.5.3 Locale: English/Philippines (en_PH) | ||||
It works perfectly fine in ver .20-25566 but is already broken by build 26155. Im not sure exactly which version was the first it broke in since i dont have all the appimages that were in between 25566 and 26155. only a couple appimages came out between these builds at most |
When the next weekly builds (should be tomorrow), can you please re-test? I made some changes to spreadsheet this week, and in my testing the recompute was working fine. |
thank you chennes, ill get back to you. ciao |
i tested the latest build (26306), this issue has been resolved, thank you |
Thanks for the update, closing the ticket. |
| 2021-11-02 05:55 | sceptre357 | New Issue | |
| 2021-11-03 23:30 | chennes | Assigned To | => chennes |
| 2021-11-03 23:30 | chennes | Status | new => assigned |
| 2021-11-04 07:58 | sceptre357 | Note Added: 0016014 | |
| 2021-11-06 15:58 | chennes | Note Added: 0016017 | |
| 2021-11-06 23:43 | sceptre357 | Note Added: 0016018 | |
| 2021-11-07 13:10 | sceptre357 | Note Added: 0016019 | |
| 2021-11-07 22:34 | chennes | Status | assigned => closed |
| 2021-11-07 22:34 | chennes | Resolution | open => fixed |
| 2021-11-07 22:34 | chennes | Fixed in Version | => 0.20 |
| 2021-11-07 22:34 | chennes | Note Added: 0016020 |
