| 0000479 | FreeCAD | Bug | public | 2011-11-10 17:47 | 2011-12-10 11:15 |
| Summary | 0000479: Pad: negative value is not allowed | ||||
| Description | There is an inconsistency in the TaskDlgPadParameters class. The input widget allows to set negative values but when pressing OK an error occurs that negative values are not permitted. Then there is also a bug in App::PropertyLength. It's derived from PropertyFloat and thus the setValue() method accepts negative values while setPyObject() doesn't. So, it's probably better to inherit from PropertyFloatConstraint and disallow negative values also from C++ side. | ||||
Pad feature checks for Length and throws an exception if needed. Pad task panel uses a minimum value of zero and checks the status of the pad. If it is invalid it thrown an exception. PropertyLength hasn't changed because this will be changed once the unit framework is implemented. Done in rev 5249 |
| 2011-11-10 17:47 | wmayer | New Issue | |
| 2011-11-10 17:47 | wmayer | Status | new => assigned |
| 2011-11-10 17:47 | wmayer | Assigned To | => Jriegel |
| 2011-12-10 11:15 | wmayer | Note Added: 0001437 | |
| 2011-12-10 11:15 | wmayer | Status | assigned => closed |
| 2011-12-10 11:15 | wmayer | Resolution | open => fixed |
| 2011-12-10 11:15 | wmayer | Fixed in Version | => 0.13 |
