| 0004790 | FreeCAD | Bug | public | 2021-11-19 15:41 | 2021-12-04 23:16 |
| Reporter | mantrap_smart0g | Assigned To | openBrain | ||
| Fixed in Version | 0.20 | ||||
| Summary | 0004790: App totally closes when trying to Select all constraints using Cmd + A | ||||
| Description | While trying to delete all constraints of a sketch using the keyboard shortcut Cmd + A, the FreeCad application closes. | ||||
| Steps To Reproduce | 1. Open FreeCAD 2. Press the "create new document" button 3. Switch to the Part Design workbench 4. Create a body then the sketch 5. Draw anything, to better reproduce make a rectangle using polyline. 6. Leave the sketch and open it again. 7. Select a constraint and the try select all with Cmd + A 8. The following error appear: "Select at least one ellipse and one edge from the sketch." 9. Try to select more than one constraint, like select two, then press the default select all keyboard shortcut with Command (Cmd ⌘) + A 10. The FreeCAD application closes suddenly. | ||||
| Additional Information | ------------------------------------- Translated Report (Full Report Below) ------------------------------------- Process: freecad [1296] Path: /Applications/FreeCAD.app/Contents/Resources/bin/freecad Identifier: freecad Version: ??? Code Type: X86-64 (Native) Parent Process: Exited process [1290] User ID: 502 Date/Time: 2021-11-19 12:24:13.5436 -0300 OS Version: macOS 12.0.1 (21A559) Report Version: 12 Anonymous UUID: C1DB9182-4789-DC0B-D4C2-9808FEEB2E67 Sleep/Wake UUID: C0AD82F0-B446-4F51-A947-16D5B9B2158F Time Awake Since Boot: 3300 seconds Time Since Wake: 952 seconds System Integrity Protection: enabled Crashed Thread: 0 CrBrowserMain Dispatch queue: com.apple.main-thread Exception Type: EXC_BAD_ACCESS (SIGSEGV) Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000 Exception Codes: 0x0000000000000001, 0x0000000000000000 Exception Note: EXC_CORPSE_NOTIFY Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11 Terminating Process: exc handler [1296] VM Region Info: 0 is not in any region. Bytes before following region: 4434665472 REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL UNUSED SPACE AT START ---> __TEXT 10853a000-108542000 [ 32K] r-x/r-x SM=COW ...s/bin/freecad Thread 0 Crashed:: CrBrowserMain Dispatch queue: com.apple.main-thread 0 SketcherGui.so 0x133c33eec CmdSketcherConstrainInternalAlignment::activated(int) + 956 1 libFreeCADGui.dylib 0x1097251fd Gui::Command::invoke(int, Gui::Command::TriggerSource) + 941 2 libQt5Core.5.12.9.dylib 0x10b559d64 QMetaObject::activate(QObject*, int, int, void**) + 1800 Thread 1:: com.apple.CFSocket.private 0 libsystem_kernel.dylib 0x7ff819769e4a __select + 10 1 CoreFoundation 0x7ff81988ce1d __CFSocketManager + 630 2 libsystem_pthread.dylib 0x7ff81979e514 _pthread_start + 125 3 libsystem_pthread.dylib 0x7ff81979a02f thread_start + 15 Thread 2:: com.apple.NSEventThread 0 libsystem_kernel.dylib 0x7ff819761aba mach_msg_trap + 10 1 libsystem_kernel.dylib 0x7ff819761e2b mach_msg + 59 2 CoreFoundation 0x7ff819865a42 __CFRunLoopServiceMachPort + 319 3 CoreFoundation 0x7ff81986411b __CFRunLoopRun + 1325 4 CoreFoundation 0x7ff81986352d CFRunLoopRunSpecific + 563 5 AppKit 0x7ff81c3fccec _NSEventThread + 132 6 libsystem_pthread.dylib 0x7ff81979e514 _pthread_start + 125 7 libsystem_pthread.dylib 0x7ff81979a02f thread_start + 15 Thread 3:: NetworkConfigWatcher 0 libsystem_kernel.dylib 0x7ff819761aba mach_msg_trap + 10 1 libsystem_kernel.dylib 0x7ff819761e2b mach_msg + 59 2 libQt5WebEngineCore.5.12.9.dylib 0x11e2315ba 0x11c54f000 + 30287290 3 libQt5WebEngineCore.5.12.9.dylib 0x11e2314bf 0x11c54f000 + 30287039 4 libQt5WebEngineCore.5.12.9.dylib 0x11e1e94c2 0x11c54f000 + 29992130 5 libQt5WebEngineCore.5.12.9.dylib 0x11e2129e5 0x11c54f000 + 30161381 6 libQt5WebEngineCore.5.12.9.dylib 0x11e2606ec 0x11c54f000 + 30480108 7 libQt5WebEngineCore.5.12.9.dylib 0x11e2a12f7 0x11c54f000 + 30745335 8 libsystem_pthread.dylib 0x7ff81979e514 _pthread_start + 125 9 libsystem_pthread.dylib 0x7ff81979a02f thread_start + 15 Thread 4:: DnsConfigService 0 libsystem_kernel.dylib 0x7ff81976645e kevent + 10 1 libQt5WebEngineCore.5.12.9.dylib 0x11e4deeed 0x11c54f000 + 33095405 2 libQt5WebEngineCore.5.12.9.dylib 0x11e4dccf8 0x11c54f000 + 33086712 3 libQt5WebEngineCore.5.12.9.dylib 0x11e2a77aa 0x11c54f000 + 30771114 4 libQt5WebEngineCore.5.12.9.dylib 0x11e2129e5 0x11c54f000 + 30161381 5 libQt5WebEngineCore.5.12.9.dylib 0x11e2606ec 0x11c54f000 + 30480108 6 libQt5WebEngineCore.5.12.9.dylib 0x11e2a12f7 0x11c54f000 + 30745335 7 libsystem_pthread.dylib 0x7ff81979e514 _pthread_start + 125 8 libsystem_pthread.dylib 0x7ff81979a02f thread_start + 15 Thread 5:: TaskSchedulerServiceThread 0 libsystem_kernel.dylib 0x7ff81976645e kevent + 10 1 libQt5WebEngineCore.5.12.9.dylib 0x11e4deeed 0x11c54f000 + 33095405 2 libQt5WebEngineCore.5.12.9.dylib 0x11e4dccf8 0x11c54f000 + 33086712 3 libQt5WebEngineCore.5.12.9.dylib 0x11e2a7791 0x11c54f000 + 30771089 4 libQt5WebEngineCore.5.12.9.dylib 0x11e2129e5 0x11c54f000 + 30161381 5 libQt5WebEngineCore.5.12.9.dylib 0x11e24fc64 0x11c54f000 + 30411876 6 libQt5WebEngineCore.5.12.9.dylib 0x11e2606ec 0x11c54f000 + 30480108 7 libQt5WebEngineCore.5.12.9.dylib 0x11e2a12f7 0x11c54f000 + 30745335 8 libsystem_pthread.dylib 0x7ff81979e514 _pthread_start + 125 9 libsystem_pthread.dylib 0x7ff81979a02f thread_start + 15 Thread 6:: TaskSchedulerForegroundWorker 0 libsystem_kernel.dylib 0x7ff819761aba mach_msg_trap + 10 1 libsystem_kernel.dylib 0x7ff819761e2b mach_msg + 59 2 libQt5WebEngineCore.5.12.9.dylib 0x11e2315ba 0x11c54f000 + 30287290 3 libQt5WebEngineCore.5.12.9.dylib 0x11e2316b1 0x11c54f000 + 30287537 4 libQt5WebEngineCore.5.12.9.dylib 0x11e249178 0x11c54f000 + 30384504 5 libQt5WebEngineCore.5.12.9.dylib 0x11e249ac8 0x11c54f000 + 30386888 6 libQt5WebEngineCore.5.12.9.dylib 0x11e249714 0x11c54f000 + 30385940 7 libQt5WebEngineCore.5.12.9.dylib 0x11e2a12f7 0x11c54f000 + 30745335 8 libsystem_pthread.dylib 0x7ff81979e514 _pthread_start + 125 9 libsystem_pthread.dylib 0x7ff81979a02f thread_start + 15 Thread 7:: TaskSchedulerForegroundBlockingWorker 0 libsystem_kernel.dylib 0x7ff819761aba mach_msg_trap + 10 1 libsystem_kernel.dylib 0x7ff819761e2b mach_msg + 59 2 libQt5WebEngineCore.5.12.9.dylib 0x11e2315ba 0x11c54f000 + 30287290 3 libQt5WebEngineCore.5.12.9.dylib 0x11e2316b1 0x11c54f000 + 30287537 4 libQt5WebEngineCore.5.12.9.dylib 0x11e249178 0x11c54f000 + 30384504 5 libQt5WebEngineCore.5.12.9.dylib 0x11e249ac8 0x11c54f000 + 30386888 6 libQt5WebEngineCore.5.12.9.dylib 0x11e249714 0x11c54f000 + 30385940 7 libQt5WebEngineCore.5.12.9.dylib 0x11e2a12f7 0x11c54f000 + 30745335 8 libsystem_pthread.dylib 0x7ff81979e514 _pthread_start + 125 9 libsystem_pthread.dylib 0x7ff81979a02f thread_start + 15 Thread 8:: TaskSchedulerBackgroundWorker 0 libsystem_kernel.dylib 0x7ff819761aba mach_msg_trap + 10 1 libsystem_kernel.dylib 0x7ff819761e2b mach_msg + 59 2 libQt5WebEngineCore.5.12.9.dylib 0x11e2315ba 0x11c54f000 + 30287290 3 libQt5WebEngineCore.5.12.9.dylib 0x11e2316b1 0x11c54f000 + 30287537 4 libQt5WebEngineCore.5.12.9.dylib 0x11e249178 0x11c54f000 + 30384504 5 libQt5WebEngineCore.5.12.9.dylib 0x11e249ac8 0x11c54f000 + 30386888 6 libQt5WebEngineCore.5.12.9.dylib 0x11e249684 0x11c54f000 + 30385796 7 libQt5WebEngineCore.5.12.9.dylib 0x11e2a12f7 0x11c54f000 + 30745335 8 libsystem_pthread.dylib 0x7ff81979e514 _pthread_start + 125 9 libsystem_pthread.dylib 0x7ff81979a02f thread_start + 15 Thread 9:: Chrome_IOThread 0 libsystem_kernel.dylib 0x7ff81976645e kevent + 10 1 libQt5WebEngineCore.5.12.9.dylib 0x11e4deeed 0x11c54f000 + 33095405 2 libQt5WebEngineCore.5.12.9.dylib 0x11e4dccf8 0x11c54f000 + 33086712 3 libQt5WebEngineCore.5.12.9.dylib 0x11e2a7791 0x11c54f000 + 30771089 4 libQt5WebEngineCore.5.12.9.dylib 0x11e2129e5 0x11c54f000 + 30161381 5 libQt5WebEngineCore.5.12.9.dylib 0x11dcb4a63 0x11c54f000 + 24533603 6 libQt5WebEngineCore.5.12.9.dylib 0x11e2606ec 0x11c54f000 + 30480108 7 libQt5WebEngineCore.5.12.9.dylib 0x11e2a12f7 0x11c54f000 + 30745335 8 libsystem_pthread.dylib 0x7ff81979e514 _pthread_start + 125 9 libsystem_pthread.dylib 0x7ff81979a02f thread_start + 15 Thread 10:: TaskSchedulerSingleThreadSharedBackgroundBlocking0 0 libsystem_kernel.dylib 0x7ff819761aba mach_msg_trap + 10 1 libsystem_kernel.dylib 0x7ff819761e2b mach_msg + 59 2 libQt5WebEngineCore.5.12.9.dylib 0x11e2315ba 0x11c54f000 + 30287290 3 libQt5WebEngineCore.5.12.9.dylib 0x11e2314bf 0x11c54f000 + 30287039 4 libQt5WebEngineCore.5.12.9.dylib 0x11e24916a 0x11c54f000 + 30384490 5 libQt5WebEngineCore.5.12.9.dylib 0x11e249812 0x11c54f000 + 30386194 6 libQt5WebEngineCore.5.12.9.dylib 0x11e2496b4 0x11c54f000 + 30385844 7 libQt5WebEngineCore.5.12.9.dylib 0x11e2a12f7 0x11c54f000 + 30745335 8 libsystem_pthread.dylib 0x7ff81979e514 _pthread_start + 125 9 libsystem_pthread.dylib 0x7ff81979a02f thread_start + 15 Thread 11:: CompositorTileWorker1/71691 0 libsystem_kernel.dylib 0x7ff819764506 __psynch_cvwait + 10 1 libsystem_pthread.dylib 0x7ff81979ea89 _pthread_cond_wait + 1224 2 libQt5WebEngineCore.5.12.9.dylib 0x11e29fba8 0x11c54f000 + 30739368 3 libQt5WebEngineCore.5.12.9.dylib 0x11ee0d1ef 0x11c54f000 + 42721775 4 libQt5WebEngineCore.5.12.9.dylib 0x11e25f314 0x11c54f000 + 30475028 5 libQt5WebEngineCore.5.12.9.dylib 0x11e2a12f7 0x11c54f000 + 30745335 6 libsystem_pthread.dylib 0x7ff81979e514 _pthread_start + 125 7 libsystem_pthread.dylib 0x7ff81979a02f thread_start + 15 Thread 12:: AudioThread 0 libsystem_kernel.dylib 0x7ff819761aba mach_msg_trap + 10 1 libsystem_kernel.dylib 0x7ff819761e2b mach_msg + 59 2 libQt5WebEngineCore.5.12.9.dylib 0x11e2315ba 0x11c54f000 + 30287290 3 libQt5WebEngineCore.5.12.9.dylib 0x11e2314bf 0x11c54f000 + 30287039 4 libQt5WebEngineCore.5.12.9.dylib 0x11e1e94c2 0x11c54f000 + 29992130 5 libQt5WebEngineCore.5.12.9.dylib 0x11e2129e5 0x11c54f000 + 30161381 6 libQt5WebEngineCore.5.12.9.dylib 0x11e2606ec 0x11c54f000 + 30480108 7 libQt5WebEngineCore.5.12.9.dylib 0x11e2a12f7 0x11c54f000 + 30745335 8 libsystem_pthread.dylib 0x7ff81979e514 _pthread_start + 125 9 libsystem_pthread.dylib 0x7ff81979a02f thread_start + 15 Thread 13:: NetworkConfigWatcher 0 libsystem_kernel.dylib 0x7ff819761aba mach_msg_trap + 10 1 libsystem_kernel.dylib 0x7ff819761e2b mach_msg + 59 2 libQt5WebEngineCore.5.12.9.dylib 0x11e2315ba 0x11c54f000 + 30287290 3 libQt5WebEngineCore.5.12.9.dylib 0x11e2314bf 0x11c54f000 + 30287039 4 libQt5WebEngineCore.5.12.9.dylib 0x11e1e94c2 0x11c54f000 + 29992130 5 libQt5WebEngineCore.5.12.9.dylib 0x11e2129e5 0x11c54f000 + 30161381 6 libQt5WebEngineCore.5.12.9.dylib 0x11e2606ec 0x11c54f000 + 30480108 7 libQt5WebEngineCore.5.12.9.dylib 0x11e2a12f7 0x11c54f000 + 30745335 8 libsystem_pthread.dylib 0x7ff81979e514 _pthread_start + 125 9 libsystem_pthread.dylib 0x7ff81979a02f thread_start + 15 Thread 14:: Chrome_InProcGpuThread 0 libsystem_kernel.dylib 0x7ff819761aba mach_msg_trap + 10 1 libsystem_kernel.dylib 0x7ff819761e2b mach_msg + 59 2 libQt5WebEngineCore.5.12.9.dylib 0x11e2315ba 0x11c54f000 + 30287290 3 libQt5WebEngineCore.5.12.9.dylib 0x11e2314bf 0x11c54f000 + 30287039 4 libQt5WebEngineCore.5.12.9.dylib 0x11e1e94c2 0x11c54f000 + 29992130 5 libQt5WebEngineCore.5.12.9.dylib 0x11e2129e5 0x11c54f000 + 30161381 6 libQt5WebEngineCore.5.12.9.dylib 0x11e2606ec 0x11c54f000 + 30480108 7 libQt5WebEngineCore.5.12.9.dylib 0x11e2a12f7 0x11c54f000 + 30745335 8 libsystem_pthread.dylib 0x7ff81979e514 _pthread_start + 125 9 libsystem_pthread.dylib 0x7ff81979a02f thread_start + 15 Thread 15:: Chrome_ChildIOThread 0 libsystem_kernel.dylib 0x7ff81976645e kevent + 10 1 libQt5WebEngineCore.5.12.9.dylib 0x11e4deeed 0x11c54f000 + 33095405 2 libQt5WebEngineCore.5.12.9.dylib 0x11e4dccf8 0x11c54f000 + 33086712 3 libQt5WebEngineCore.5.12.9.dylib 0x11e2a77aa 0x11c54f000 + 30771114 4 libQt5WebEngineCore.5.12.9.dylib 0x11e2129e5 0x11c54f000 + 30161381 5 libQt5WebEngineCore.5.12.9.dylib 0x11e2606ec 0x11c54f000 + 30480108 6 libQt5WebEngineCore.5.12.9.dylib 0x11e2a12f7 0x11c54f000 + 30745335 7 libsystem_pthread.dylib 0x7ff81979e514 _pthread_start + 125 8 libsystem_pthread.dylib 0x7ff81979a02f thread_start + 15 Thread 16:: TaskSchedulerBackgroundBlockingWorker 0 libsystem_kernel.dylib 0x7ff819761aba mach_msg_trap + 10 1 libsystem_kernel.dylib 0x7ff819761e2b mach_msg + 59 2 libQt5WebEngineCore.5.12.9.dylib 0x11e2315ba 0x11c54f000 + 30287290 3 libQt5WebEngineCore.5.12.9.dylib 0x11e2316b1 0x11c54f000 + 30287537 4 libQt5WebEngineCore.5.12.9.dylib 0x11e249178 0x11c54f000 + 30384504 5 libQt5WebEngineCore.5.12.9.dylib 0x11e249ac8 0x11c54f000 + 30386888 6 libQt5WebEngineCore.5.12.9.dylib 0x11e249684 0x11c54f000 + 30385796 7 libQt5WebEngineCore.5.12.9.dylib 0x11e2a12f7 0x11c54f000 + 30745335 8 libsystem_pthread.dylib 0x7ff81979e514 _pthread_start + 125 9 libsystem_pthread.dylib 0x7ff81979a02f thread_start + 15 Thread 17:: TaskSchedulerSingleThreadForegroundBlocking1 0 libsystem_kernel.dylib 0x7ff819761aba mach_msg_trap + 10 1 libsystem_kernel.dylib 0x7ff819761e2b mach_msg + 59 2 libQt5WebEngineCore.5.12.9.dylib 0x11e2315ba 0x11c54f000 + 30287290 3 libQt5WebEngineCore.5.12.9.dylib 0x11e2314bf 0x11c54f000 + 30287039 4 libQt5WebEngineCore.5.12.9.dylib 0x11e24916a 0x11c54f000 + 30384490 5 libQt5WebEngineCore.5.12.9.dylib 0x11e249ac8 0x11c54f000 + 30386888 6 libQt5WebEngineCore.5.12.9.dylib 0x11e249774 0x11c54f000 + 30386036 7 libQt5WebEngineCore.5.12.9.dylib 0x11e2a12f7 0x11c54f000 + 30745335 8 libsystem_pthread.dylib 0x7ff81979e514 _pthread_start + 125 9 libsystem_pthread.dylib 0x7ff81979a02f thread_start + 15 Thread 18:: CacheThread_BlockFile 0 libsystem_kernel.dylib 0x7ff81976645e kevent + 10 1 libQt5WebEngineCore.5.12.9.dylib 0x11e4deeed 0x11c54f000 + 33095405 2 libQt5WebEngineCore.5.12.9.dylib 0x11e4dccf8 0x11c54f000 + 33086712 3 libQt5WebEngineCore.5.12.9.dylib 0x11e2a7791 0x11c54f000 + 30771089 4 libQt5WebEngineCore.5.12.9.dylib 0x11e2129e5 0x11c54f000 + 30161381 5 libQt5WebEngineCore.5.12.9.dylib 0x11e2606ec 0x11c54f000 + 30480108 6 libQt5WebEngineCore.5.12.9.dylib 0x11e2a12f7 0x11c54f000 + 30745335 7 libsystem_pthread.dylib 0x7ff81979e514 _pthread_start + 125 8 libsystem_pthread.dylib 0x7ff81979a02f thread_start + 15 Thread 19: 0 libsystem_kernel.dylib 0x7ff819764506 __psynch_cvwait + 10 1 libsystem_pthread.dylib 0x7ff81979ea89 _pthread_cond_wait + 1224 2 libomp.dylib 0x130df216b __kmp_suspend_64 + 299 3 libomp.dylib 0x130dda930 kmp_flag_64::wait(kmp_info*, int, void*) + 1552 4 libomp.dylib 0x130dd67d6 __kmp_hyper_barrier_release(barrier_type, kmp_info*, int, int, int, void*) + 166 5 libomp.dylib 0x130dd9f5d __kmp_fork_barrier(int, int) + 445 6 libomp.dylib 0x130db975a __kmp_launch_thread + 314 7 libomp.dylib 0x130df0c1a __kmp_launch_worker(void*) + 330 8 libsystem_pthread.dylib 0x7ff81979e514 _pthread_start + 125 9 libsystem_pthread.dylib 0x7ff81979a02f thread_start + 15 Thread 20: 0 libsystem_kernel.dylib 0x7ff819764506 __psynch_cvwait + 10 1 libsystem_pthread.dylib 0x7ff81979ea89 _pthread_cond_wait + 1224 2 libomp.dylib 0x130df216b __kmp_suspend_64 + 299 3 libomp.dylib 0x130dda930 kmp_flag_64::wait(kmp_info*, int, void*) + 1552 4 libomp.dylib 0x130dd67d6 __kmp_hyper_barrier_release(barrier_type, kmp_info*, int, int, int, void*) + 166 5 libomp.dylib 0x130dd9f5d __kmp_fork_barrier(int, int) + 445 6 libomp.dylib 0x130db975a __kmp_launch_thread + 314 7 libomp.dylib 0x130df0c1a __kmp_launch_worker(void*) + 330 8 libsystem_pthread.dylib 0x7ff81979e514 _pthread_start + 125 9 libsystem_pthread.dylib 0x7ff81979a02f thread_start + 15 Thread 21: 0 libsystem_kernel.dylib 0x7ff819764506 __psynch_cvwait + 10 1 libsystem_pthread.dylib 0x7ff81979ea89 _pthread_cond_wait + 1224 2 libomp.dylib 0x130df216b __kmp_suspend_64 + 299 3 libomp.dylib 0x130dda930 kmp_flag_64::wait(kmp_info*, int, void*) + 1552 4 libomp.dylib 0x130dd67d6 __kmp_hyper_barrier_release(barrier_type, kmp_info*, int, int, int, void*) + 166 5 libomp.dylib 0x130dd9f5d __kmp_fork_barrier(int, int) + 445 6 libomp.dylib 0x130db975a __kmp_launch_thread + 314 7 libomp.dylib 0x130df0c1a __kmp_launch_worker(void*) + 330 8 libsystem_pthread.dylib 0x7ff81979e514 _pthread_start + 125 9 libsystem_pthread.dylib 0x7ff81979a02f thread_start + 15 Thread 22: 0 libsystem_pthread.dylib 0x7ff81979a00c start_wqthread + 0 Thread 23: 0 libsystem_pthread.dylib 0x7ff81979a00c start_wqthread + 0 Thread 24: 0 libsystem_pthread.dylib 0x7ff81979a00c start_wqthread + 0 Thread 0 crashed with X86 Thread State (64-bit): rax: 0x0000000000000000 rbx: 0x00007fd6a8972000 rcx: 0x00000000000007d0 rdx: 0x0000000000000002 rdi: 0x00007fd6a8972000 rsi: 0x00000000fffff830 rbp: 0x00007ff7b79c2ef0 rsp: 0x00007ff7b79c2d60 r8: 0x0000000000000056 r9: 0x0000000000000030 r10: 0x00000000000007fb r11: 0x00001ff7b657a588 r12: 0x0000600004173840 r13: 0x0000600002aeda70 r14: 0x0000000000000000 r15: 0x0000600001448780 rip: 0x0000000133c33eec rfl: 0x0000000000010246 cr2: 0x0000000000000000 Logical CPU: 2 Error Code: 0x00000004 (no mapping for user data read) Trap Number: 14 Thread 0 instruction stream: 80 c1 fc ff 8b b5 ac fe-ff ff 48 89 df e8 62 bb ..........H...b. fc ff 8b b5 ac fe ff ff-84 c0 74 2e 3b b5 90 fe ..........t.;... ff ff 0f 84 d4 07 00 00-3b b5 94 fe ff ff 0f 84 ........;....... c8 07 00 00 f6 85 88 fe-ff ff 01 b0 01 48 89 85 .............H.. 88 fe ff ff 0f 85 21 08-00 00 4c 89 bd 78 fe ff ......!...L..x.. ff 48 8b bd 98 fe ff ff-e8 cf 34 0d 00 49 89 c6 .H........4..I.. [48]8b 00 4c 8d a5 30 ff-ff ff 4c 89 e7 4c 89 f6 H..L..0...L..L.. <== ff 10 48 8d 5d 90 48 89-df e8 a8 25 0d 00 44 8b ..H.].H....%..D. bd 38 ff ff ff 44 8b 6d-98 48 89 df e8 63 24 0d .8...D.m.H...c$. 00 4c 89 e7 e8 5b 24 0d-00 45 39 ef 0f 84 02 ff .L...[$..E9..... ff ff 49 8b 06 4c 89 e7-4c 89 f6 ff 10 48 8d 5d ..I..L..L....H.] 80 48 89 df e8 2b 25 0d-00 48 89 df 44 8b bd 38 .H...+%..H..D..8 Binary Images: 0x133bc1000 - 0x133f17fff SketcherGui.so (*) <507539cb-a426-3cb1-8e60-90f62f096e0c> /Applications/FreeCAD.app/Contents/Resources/lib/SketcherGui.so 0x10962a000 - 0x10a1b0fff libFreeCADGui.dylib (*) <0824943b-7533-31de-9365-7933f6c4de31> /Applications/FreeCAD.app/Contents/Resources/lib/libFreeCADGui.dylib 0x10b41b000 - 0x10b7bbfff libQt5Core.5.12.9.dylib (*) <cfcfe7c0-8cd1-39e0-a333-401310dc044d> /Applications/FreeCAD.app/Contents/Resources/lib/libQt5Core.5.12.9.dylib 0x7ff819761000 - 0x7ff819797fff libsystem_kernel.dylib (*) <12bd6f13-c452-35ee-9069-51befef29f1a> /usr/lib/system/libsystem_kernel.dylib 0x7ff8197e5000 - 0x7ff819ce7fff com.apple.CoreFoundation (6.9) <3002b545-6841-3fc8-91a2-bcfbe5872465> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7ff819798000 - 0x7ff8197a3fff libsystem_pthread.dylib (*) <29a2750e-f31b-3630-8761-242a6bc3e99e> /usr/lib/system/libsystem_pthread.dylib 0x7ff81c250000 - 0x7ff81d0dcfff com.apple.AppKit (6.9) <dd0028a3-78e3-3a8a-a51b-ddd68123adef> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x11c54f000 - 0x1211eefff libQt5WebEngineCore.5.12.9.dylib (*) <3277594a-e67b-38ce-b55a-2582f07c6db8> /Applications/FreeCAD.app/Contents/Resources/lib/libQt5WebEngineCore.5.12.9.dylib 0x130d99000 - 0x130e0ffff libomp.dylib (*) <14bc387f-0237-327f-b68c-c42e478d2dce> /Applications/FreeCAD.app/Contents/Resources/lib/libomp.dylib External Modification Summary: Calls made by other processes targeting this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by all processes on this machine: task_for_pid: 0 thread_create: 0 thread_set_state: 0 VM Region Summary: ReadOnly portion of Libraries: Total=1.4G resident=0K(0%) swapped_out_or_unallocated=1.4G(100%) Writable regions: Total=1.5G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.5G(100%) VIRTUAL REGION REGION TYPE SIZE COUNT (non-coalesced) =========== ======= ======= Accelerate framework 768K 6 Activity Tracing 256K 1 CG backing stores 2160K 4 CG image 352K 24 ColorSync 240K 28 CoreAnimation 476K 14 CoreGraphics 12K 2 CoreUI image data 3672K 30 Foundation 32K 2 Kernel Alloc Once 8K 1 MALLOC 288.5M 301 MALLOC guard page 32K 8 MALLOC_LARGE (reserved) 640K 2 reserved VM address space (unallocated) MALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated) MALLOC_REALLOC (reserved) 16K 1 reserved VM address space (unallocated) OpenGL GLSL 256K 3 PROTECTED_MEMORY 4K 1 STACK GUARD 56.1M 25 Stack 162.7M 25 VM_ALLOCATE 390.7M 39 VM_ALLOCATE (reserved) 256.0M 2 reserved VM address space (unallocated) __DATA 42.3M 700 __DATA_CONST 29.3M 334 __DATA_DIRTY 1574K 210 __FONT_DATA 4K 1 __GLSLBUILTINS 5176K 1 __LINKEDIT 683.3M 160 __OBJC_RO 81.5M 1 __OBJC_RW 3120K 2 __TEXT 779.3M 674 __UNICODE 588K 1 dyld private memory 1536K 3 mapped file 207.0M 59 shared memory 780K 19 =========== ======= ======= TOTAL 3.3G 2685 TOTAL, minus reserved VM space 2.7G 2685 ----------- Full Report ----------- {"app_name":"freecad","timestamp":"2021-11-19 12:24:30.00 -0300","app_version":"","slice_uuid":"b66d5c0c-2273-3b53-9c7e-0310af8abdee","build_version":"","platform":1,"share_with_app_devs":0,"is_first_party":1,"bug_type":"309","os_version":"macOS 12.0.1 (21A559)","incident_id":"B9A26AF9-F4E1-4843-BCAA-2EB780E8F500","name":"freecad"} { "uptime" : 3300, "procLaunch" : "2021-11-19 12:17:34.0086 -0300", "procRole" : "Foreground", "version" : 2, "userID" : 502, "deployVersion" : 210, "modelCode" : "MacBookPro12,1", "procStartAbsTime" : 2970604669310, "coalitionID" : 892, "osVersion" : { "train" : "macOS 12.0.1", "build" : "21A559", "releaseType" : "User" }, "captureTime" : "2021-11-19 12:24:13.5436 -0300", "incident" : "B9A26AF9-F4E1-4843-BCAA-2EB780E8F500", "bug_type" : "309", "pid" : 1296, "procExitAbsTime" : 3370117510619, "cpuType" : "X86-64", "procName" : "freecad", "procPath" : "\/Applications\/FreeCAD.app\/Contents\/Resources\/bin\/freecad", "parentProc" : "Exited process", "parentPid" : 1290, "crashReporterKey" : "C1DB9182-4789-DC0B-D4C2-9808FEEB2E67", "responsiblePid" : 1290, "wakeTime" : 952, "sleepWakeUUID" : "C0AD82F0-B446-4F51-A947-16D5B9B2158F", "sip" : "enabled", "vmRegionInfo" : "0 is not in any region. Bytes before following region: 4434665472\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n __TEXT 10853a000-108542000 [ 32K] r-x\/r-x SM=COW ...s\/bin\/freecad", "isCorpse" : 1, "exception" : {"codes":"0x0000000000000001, 0x0000000000000000","rawCodes":[1,0],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x0000000000000000"}, "termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":1296}, "vmregioninfo" : "0 is not in any region. Bytes before following region: 4434665472\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n---> \n __TEXT 10853a000-108542000 [ 32K] r-x\/r-x SM=COW ...s\/bin\/freecad", "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0}, "faultingThread" : 0, "threads" : [{"queue":"com.apple.main-thread","instructionState":{"instructionStream":{"bytes":[128,193,252,255,139,181,172,254,255,255,72,137,223,232,98,187,252,255,139,181,172,254,255,255,132,192,116,46,59,181,144,254,255,255,15,132,212,7,0,0,59,181,148,254,255,255,15,132,200,7,0,0,246,133,136,254,255,255,1,176,1,72,137,133,136,254,255,255,15,133,33,8,0,0,76,137,189,120,254,255,255,72,139,189,152,254,255,255,232,207,52,13,0,73,137,198,72,139,0,76,141,165,48,255,255,255,76,137,231,76,137,246,255,16,72,141,93,144,72,137,223,232,168,37,13,0,68,139,189,56,255,255,255,68,139,109,152,72,137,223,232,99,36,13,0,76,137,231,232,91,36,13,0,69,57,239,15,132,2,255,255,255,73,139,6,76,137,231,76,137,246,255,16,72,141,93,128,72,137,223,232,43,37,13,0,72,137,223,68,139,189,56],"offset":96}},"frames":[{"imageOffset":470764,"symbol":"CmdSketcherConstrainInternalAlignment::activated(int)","symbolLocation":956,"imageIndex":0},{"imageOffset":1028605,"symbol":"Gui::Command::invoke(int, Gui::Command::TriggerSource)","symbolLocation":941,"imageIndex":1},{"imageOffset":1305956,"symbol":"QMetaObject::activate(QObject*, int, int, void**)","symbolLocation":1800,"imageIndex":2}],"id":37093,"triggered":true,"threadState":{"r13":{"value":105553161280112},"rax":{"value":0},"rflags":{"value":66118},"cpu":{"value":2},"r14":{"value":0},"rsi":{"value":4294965296},"r8":{"value":86},"cr2":{"value":0},"rdx":{"value":2},"r10":{"value":2043},"r9":{"value":48},"r15":{"value":105553137534848},"rbx":{"value":140559928205312},"trap":{"value":14,"description":"(no mapping for user data read)"},"err":{"value":4},"r11":{"value":35148776580488},"rip":{"value":5163400940,"matchesCrashFrame":1},"rbp":{"value":140701914115824},"rsp":{"value":140701914115424},"r12":{"value":105553184897088},"rcx":{"value":2000},"flavor":"x86_THREAD_STATE","rdi":{"value":140559928205312}},"name":"CrBrowserMain"},{"id":37109,"name":"com.apple.CFSocket.private","frames":[{"imageOffset":36426,"symbol":"__select","symbolLocation":10,"imageIndex":3},{"imageOffset":687645,"symbol":"__CFSocketManager","symbolLocation":630,"imageIndex":4},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":37115,"name":"com.apple.NSEventThread","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":3},{"imageOffset":526914,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":4},{"imageOffset":520475,"symbol":"__CFRunLoopRun","symbolLocation":1325,"imageIndex":4},{"imageOffset":517421,"symbol":"CFRunLoopRunSpecific","symbolLocation":563,"imageIndex":4},{"imageOffset":1756396,"symbol":"_NSEventThread","symbolLocation":132,"imageIndex":6},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":37193,"name":"NetworkConfigWatcher","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":3},{"imageOffset":30287290,"imageIndex":7},{"imageOffset":30287039,"imageIndex":7},{"imageOffset":29992130,"imageIndex":7},{"imageOffset":30161381,"imageIndex":7},{"imageOffset":30480108,"imageIndex":7},{"imageOffset":30745335,"imageIndex":7},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":37194,"name":"DnsConfigService","frames":[{"imageOffset":21598,"symbol":"kevent","symbolLocation":10,"imageIndex":3},{"imageOffset":33095405,"imageIndex":7},{"imageOffset":33086712,"imageIndex":7},{"imageOffset":30771114,"imageIndex":7},{"imageOffset":30161381,"imageIndex":7},{"imageOffset":30480108,"imageIndex":7},{"imageOffset":30745335,"imageIndex":7},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":37195,"name":"TaskSchedulerServiceThread","frames":[{"imageOffset":21598,"symbol":"kevent","symbolLocation":10,"imageIndex":3},{"imageOffset":33095405,"imageIndex":7},{"imageOffset":33086712,"imageIndex":7},{"imageOffset":30771089,"imageIndex":7},{"imageOffset":30161381,"imageIndex":7},{"imageOffset":30411876,"imageIndex":7},{"imageOffset":30480108,"imageIndex":7},{"imageOffset":30745335,"imageIndex":7},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":37196,"name":"TaskSchedulerForegroundWorker","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":3},{"imageOffset":30287290,"imageIndex":7},{"imageOffset":30287537,"imageIndex":7},{"imageOffset":30384504,"imageIndex":7},{"imageOffset":30386888,"imageIndex":7},{"imageOffset":30385940,"imageIndex":7},{"imageOffset":30745335,"imageIndex":7},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":37198,"name":"TaskSchedulerForegroundBlockingWorker","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":3},{"imageOffset":30287290,"imageIndex":7},{"imageOffset":30287537,"imageIndex":7},{"imageOffset":30384504,"imageIndex":7},{"imageOffset":30386888,"imageIndex":7},{"imageOffset":30385940,"imageIndex":7},{"imageOffset":30745335,"imageIndex":7},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":37200,"name":"TaskSchedulerBackgroundWorker","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":3},{"imageOffset":30287290,"imageIndex":7},{"imageOffset":30287537,"imageIndex":7},{"imageOffset":30384504,"imageIndex":7},{"imageOffset":30386888,"imageIndex":7},{"imageOffset":30385796,"imageIndex":7},{"imageOffset":30745335,"imageIndex":7},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":37202,"name":"Chrome_IOThread","frames":[{"imageOffset":21598,"symbol":"kevent","symbolLocation":10,"imageIndex":3},{"imageOffset":33095405,"imageIndex":7},{"imageOffset":33086712,"imageIndex":7},{"imageOffset":30771089,"imageIndex":7},{"imageOffset":30161381,"imageIndex":7},{"imageOffset":24533603,"imageIndex":7},{"imageOffset":30480108,"imageIndex":7},{"imageOffset":30745335,"imageIndex":7},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":37203,"name":"TaskSchedulerSingleThreadSharedBackgroundBlocking0","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":3},{"imageOffset":30287290,"imageIndex":7},{"imageOffset":30287039,"imageIndex":7},{"imageOffset":30384490,"imageIndex":7},{"imageOffset":30386194,"imageIndex":7},{"imageOffset":30385844,"imageIndex":7},{"imageOffset":30745335,"imageIndex":7},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":37204,"name":"CompositorTileWorker1\/71691","frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":3},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":5},{"imageOffset":30739368,"imageIndex":7},{"imageOffset":42721775,"imageIndex":7},{"imageOffset":30475028,"imageIndex":7},{"imageOffset":30745335,"imageIndex":7},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":37205,"name":"AudioThread","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":3},{"imageOffset":30287290,"imageIndex":7},{"imageOffset":30287039,"imageIndex":7},{"imageOffset":29992130,"imageIndex":7},{"imageOffset":30161381,"imageIndex":7},{"imageOffset":30480108,"imageIndex":7},{"imageOffset":30745335,"imageIndex":7},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":37206,"name":"NetworkConfigWatcher","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":3},{"imageOffset":30287290,"imageIndex":7},{"imageOffset":30287039,"imageIndex":7},{"imageOffset":29992130,"imageIndex":7},{"imageOffset":30161381,"imageIndex":7},{"imageOffset":30480108,"imageIndex":7},{"imageOffset":30745335,"imageIndex":7},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":37207,"name":"Chrome_InProcGpuThread","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":3},{"imageOffset":30287290,"imageIndex":7},{"imageOffset":30287039,"imageIndex":7},{"imageOffset":29992130,"imageIndex":7},{"imageOffset":30161381,"imageIndex":7},{"imageOffset":30480108,"imageIndex":7},{"imageOffset":30745335,"imageIndex":7},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":37208,"name":"Chrome_ChildIOThread","frames":[{"imageOffset":21598,"symbol":"kevent","symbolLocation":10,"imageIndex":3},{"imageOffset":33095405,"imageIndex":7},{"imageOffset":33086712,"imageIndex":7},{"imageOffset":30771114,"imageIndex":7},{"imageOffset":30161381,"imageIndex":7},{"imageOffset":30480108,"imageIndex":7},{"imageOffset":30745335,"imageIndex":7},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":37218,"name":"TaskSchedulerBackgroundBlockingWorker","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":3},{"imageOffset":30287290,"imageIndex":7},{"imageOffset":30287537,"imageIndex":7},{"imageOffset":30384504,"imageIndex":7},{"imageOffset":30386888,"imageIndex":7},{"imageOffset":30385796,"imageIndex":7},{"imageOffset":30745335,"imageIndex":7},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":37220,"name":"TaskSchedulerSingleThreadForegroundBlocking1","frames":[{"imageOffset":2746,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":3627,"symbol":"mach_msg","symbolLocation":59,"imageIndex":3},{"imageOffset":30287290,"imageIndex":7},{"imageOffset":30287039,"imageIndex":7},{"imageOffset":30384490,"imageIndex":7},{"imageOffset":30386888,"imageIndex":7},{"imageOffset":30386036,"imageIndex":7},{"imageOffset":30745335,"imageIndex":7},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":37222,"name":"CacheThread_BlockFile","frames":[{"imageOffset":21598,"symbol":"kevent","symbolLocation":10,"imageIndex":3},{"imageOffset":33095405,"imageIndex":7},{"imageOffset":33086712,"imageIndex":7},{"imageOffset":30771089,"imageIndex":7},{"imageOffset":30161381,"imageIndex":7},{"imageOffset":30480108,"imageIndex":7},{"imageOffset":30745335,"imageIndex":7},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":39241,"frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":3},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":5},{"imageOffset":364907,"symbol":"__kmp_suspend_64","symbolLocation":299,"imageIndex":8},{"imageOffset":268592,"symbol":"kmp_flag_64::wait(kmp_info*, int, void*)","symbolLocation":1552,"imageIndex":8},{"imageOffset":251862,"symbol":"__kmp_hyper_barrier_release(barrier_type, kmp_info*, int, int, int, void*)","symbolLocation":166,"imageIndex":8},{"imageOffset":266077,"symbol":"__kmp_fork_barrier(int, int)","symbolLocation":445,"imageIndex":8},{"imageOffset":132954,"symbol":"__kmp_launch_thread","symbolLocation":314,"imageIndex":8},{"imageOffset":359450,"symbol":"__kmp_launch_worker(void*)","symbolLocation":330,"imageIndex":8},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":39242,"frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":3},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":5},{"imageOffset":364907,"symbol":"__kmp_suspend_64","symbolLocation":299,"imageIndex":8},{"imageOffset":268592,"symbol":"kmp_flag_64::wait(kmp_info*, int, void*)","symbolLocation":1552,"imageIndex":8},{"imageOffset":251862,"symbol":"__kmp_hyper_barrier_release(barrier_type, kmp_info*, int, int, int, void*)","symbolLocation":166,"imageIndex":8},{"imageOffset":266077,"symbol":"__kmp_fork_barrier(int, int)","symbolLocation":445,"imageIndex":8},{"imageOffset":132954,"symbol":"__kmp_launch_thread","symbolLocation":314,"imageIndex":8},{"imageOffset":359450,"symbol":"__kmp_launch_worker(void*)","symbolLocation":330,"imageIndex":8},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":39243,"frames":[{"imageOffset":13574,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":3},{"imageOffset":27273,"symbol":"_pthread_cond_wait","symbolLocation":1224,"imageIndex":5},{"imageOffset":364907,"symbol":"__kmp_suspend_64","symbolLocation":299,"imageIndex":8},{"imageOffset":268592,"symbol":"kmp_flag_64::wait(kmp_info*, int, void*)","symbolLocation":1552,"imageIndex":8},{"imageOffset":251862,"symbol":"__kmp_hyper_barrier_release(barrier_type, kmp_info*, int, int, int, void*)","symbolLocation":166,"imageIndex":8},{"imageOffset":266077,"symbol":"__kmp_fork_barrier(int, int)","symbolLocation":445,"imageIndex":8},{"imageOffset":132954,"symbol":"__kmp_launch_thread","symbolLocation":314,"imageIndex":8},{"imageOffset":359450,"symbol":"__kmp_launch_worker(void*)","symbolLocation":330,"imageIndex":8},{"imageOffset":25876,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8239,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":40410,"frames":[{"imageOffset":8204,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}]},{"id":40411,"frames":[{"imageOffset":8204,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}]},{"id":40412,"frames":[{"imageOffset":8204,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}]}], "usedImages" : [ { "source" : "P", "arch" : "x86_64", "base" : 5162930176, "size" : 3502080, "uuid" : "507539cb-a426-3cb1-8e60-90f62f096e0c", "path" : "\/Applications\/FreeCAD.app\/Contents\/Resources\/lib\/SketcherGui.so", "name" : "SketcherGui.so" }, { "source" : "P", "arch" : "x86_64", "base" : 4452425728, "size" : 12087296, "uuid" : "0824943b-7533-31de-9365-7933f6c4de31", "path" : "\/Applications\/FreeCAD.app\/Contents\/Resources\/lib\/libFreeCADGui.dylib", "name" : "libFreeCADGui.dylib" }, { "source" : "P", "arch" : "x86_64", "base" : 4483821568, "size" : 3805184, "uuid" : "cfcfe7c0-8cd1-39e0-a333-401310dc044d", "path" : "\/Applications\/FreeCAD.app\/Contents\/Resources\/lib\/libQt5Core.5.12.9.dylib", "name" : "libQt5Core.5.12.9.dylib" }, { "source" : "P", "arch" : "x86_64", "base" : 140703555784704, "size" : 225280, "uuid" : "12bd6f13-c452-35ee-9069-51befef29f1a", "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib", "name" : "libsystem_kernel.dylib" }, { "source" : "P", "arch" : "x86_64h", "base" : 140703556325376, "CFBundleShortVersionString" : "6.9", "CFBundleIdentifier" : "com.apple.CoreFoundation", "size" : 5255168, "uuid" : "3002b545-6841-3fc8-91a2-bcfbe5872465", "path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation", "name" : "CoreFoundation", "CFBundleVersion" : "1855.105" }, { "source" : "P", "arch" : "x86_64", "base" : 140703556009984, "size" : 49152, "uuid" : "29a2750e-f31b-3630-8761-242a6bc3e99e", "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib", "name" : "libsystem_pthread.dylib" }, { "source" : "P", "arch" : "x86_64", "base" : 140703600803840, "CFBundleShortVersionString" : "6.9", "CFBundleIdentifier" : "com.apple.AppKit", "size" : 15257600, "uuid" : "dd0028a3-78e3-3a8a-a51b-ddd68123adef", "path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit", "name" : "AppKit", "CFBundleVersion" : "2113" }, { "source" : "P", "arch" : "x86_64", "base" : 4770295808, "size" : 80347136, "uuid" : "3277594a-e67b-38ce-b55a-2582f07c6db8", "path" : "\/Applications\/FreeCAD.app\/Contents\/Resources\/lib\/libQt5WebEngineCore.5.12.9.dylib", "name" : "libQt5WebEngineCore.5.12.9.dylib" }, { "source" : "P", "arch" : "x86_64", "base" : 5114531840, "size" : 487424, "uuid" : "14bc387f-0237-327f-b68c-c42e478d2dce", "path" : "\/Applications\/FreeCAD.app\/Contents\/Resources\/lib\/libomp.dylib", "name" : "libomp.dylib" } ], "sharedCache" : { "base" : 140703552782336, "size" : 15213641728, "uuid" : "3d05845f-3f65-358f-9ebf-2236e772ac01" }, "vmSummary" : "ReadOnly portion of Libraries: Total=1.4G resident=0K(0%) swapped_out_or_unallocated=1.4G(100%)\nWritable regions: Total=1.5G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.5G(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 768K 6 \nActivity Tracing 256K 1 \nCG backing stores 2160K 4 \nCG image 352K 24 \nColorSync 240K 28 \nCoreAnimation 476K 14 \nCoreGraphics 12K 2 \nCoreUI image data 3672K 30 \nFoundation 32K 2 \nKernel Alloc Once 8K 1 \nMALLOC 288.5M 301 \nMALLOC guard page 32K 8 \nMALLOC_LARGE (reserved) 640K 2 reserved VM address space (unallocated)\nMALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated)\nMALLOC_REALLOC (reserved) 16K 1 reserved VM address space (unallocated)\nOpenGL GLSL 256K 3 \nPROTECTED_MEMORY 4K 1 \nSTACK GUARD 56.1M 25 \nStack 162.7M 25 \nVM_ALLOCATE 390.7M 39 \nVM_ALLOCATE (reserved) 256.0M 2 reserved VM address space (unallocated)\n__DATA 42.3M 700 \n__DATA_CONST 29.3M 334 \n__DATA_DIRTY 1574K 210 \n__FONT_DATA 4K 1 \n__GLSLBUILTINS 5176K 1 \n__LINKEDIT 683.3M 160 \n__OBJC_RO 81.5M 1 \n__OBJC_RW 3120K 2 \n__TEXT 779.3M 674 \n__UNICODE 588K 1 \ndyld private memory 1536K 3 \nmapped file 207.0M 59 \nshared memory 780K 19 \n=========== ======= ======= \nTOTAL 3.3G 2685 \nTOTAL, minus reserved VM space 2.7G 2685 \n", "legacyInfo" : { "threadTriggered" : { "name" : "CrBrowserMain", "queue" : "com.apple.main-thread" } }, "trialInfo" : { "rollouts" : [ { "rolloutId" : "607844aa04477260f58a8077", "factorPackIds" : { "SIRI_MORPHUN_ASSETS" : "6103050cbfe6dc472e1c982a" }, "deploymentId" : 240000066 }, { "rolloutId" : "60da5e84ab0ca017dace9abf", "factorPackIds" : { }, "deploymentId" : 240000008 }, { "rolloutId" : "5ffde50ce2aacd000d47a95f", "factorPackIds" : { }, "deploymentId" : 240000076 }, { "rolloutId" : "5fc94383418129005b4e9ae0", "factorPackIds" : { }, "deploymentId" : 240000162 }, { "rolloutId" : "601d9415f79519000ccd4b69", "factorPackIds" : { "SIRI_TEXT_TO_SPEECH" : "6194416dea7ed64a7812a429" }, "deploymentId" : 240000322 }, { "rolloutId" : "602ad4dac86151000cf27e46", "factorPackIds" : { "SIRI_DICTATION_ASSETS" : "614a34c5eae97a2111628dc5" }, "deploymentId" : 240000271 } ], "experiments" : [ ] } } Model: MacBookPro12,1, BootROM 428.40.10.0.0, 2 processors, Dual-Core Intel Core i5, 2.7 GHz, 8 GB, SMC 2.28f7 Graphics: Intel Iris Graphics 6100, Intel Iris Graphics 6100, Built-In Display: Color LCD, 2560 x 1600 Retina, Main, MirrorOff, Online Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1867 MHz, 0x02FE, 0x4544464132333241324D412D4A442D460000 Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1867 MHz, 0x02FE, 0x4544464132333241324D412D4A442D460000 AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x133), Broadcom BCM43xx 1.0 (7.77.111.1 AirPortDriverBrcmNIC-1710.2) AirPort: Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports Network Service: Wi-Fi, AirPort, en0 Serial ATA Device: APPLE SSD SM0128G, 121.33 GB USB Device: USB30Bus USB Device: Bluetooth USB Host Controller Thunderbolt Bus: MacBook Pro, Apple Inc., 27.1 | ||||
| Tags | #post-to-forum, constraints, crash, selection | ||||
| FreeCAD Information | OS: macOS 10.16 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.24291 (Git) Build type: Release Branch: (HEAD detached at 0.19.2) Hash: 7b5e18a0759de778b74d3a5c17eba9cb815035ac Python version: 3.8.8 Qt version: 5.12.9 Coin version: 4.0.0 OCC version: 7.4.0 Locale: C/Default (C) | ||||
@mantrap_smart0g : could you please open a new topic in our forum according our reporting guidelines ? I can reproduce the bug with 0.19 but not more with 0.20. |
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=8&t=63909 |
As reported by @chrisb on the forum:
PR submitted : https://github.com/FreeCAD/FreeCAD/pull/5190 |
| 2021-11-19 15:41 | mantrap_smart0g | New Issue | |
| 2021-11-19 15:41 | mantrap_smart0g | Tag Attached: constraints | |
| 2021-11-19 15:41 | mantrap_smart0g | Tag Attached: crash | |
| 2021-11-19 15:41 | mantrap_smart0g | Tag Attached: macOS | |
| 2021-11-19 15:41 | mantrap_smart0g | Tag Attached: Part Design | |
| 2021-11-19 15:41 | mantrap_smart0g | Tag Attached: selection | |
| 2021-11-19 17:44 | openBrain | Status | new => feedback |
| 2021-11-19 17:44 | openBrain | Note Added: 0016039 | |
| 2021-11-19 17:45 | openBrain | Tag Detached: Part Design | |
| 2021-11-19 17:45 | openBrain | Tag Detached: macOS | |
| 2021-11-19 17:45 | openBrain | Tag Attached: #post-to-forum | |
| 2021-11-19 19:54 | mantrap_smart0g | Status | feedback => new |
| 2021-11-20 15:27 | mantrap_smart0g | Note Added: 0016042 | |
| 2021-11-20 23:45 | mantrap_smart0g | Note Added: 0016043 | |
| 2021-11-20 23:45 | mantrap_smart0g | Note Edited: 0016043 | |
| 2021-11-21 18:06 | openBrain | Assigned To | => openBrain |
| 2021-11-21 18:06 | openBrain | Status | new => assigned |
| 2021-11-21 18:06 | openBrain | Note Added: 0016044 | |
| 2021-11-22 19:16 | uwestoehr | Status | assigned => resolved |
| 2021-11-22 19:16 | uwestoehr | Resolution | open => fixed |
| 2021-12-04 23:16 | wmayer | Status | resolved => closed |
| 2021-12-04 23:16 | wmayer | Fixed in Version | => 0.20 |
