| 0000480 | Drawing | Bug | public | 2011-11-11 08:54 | 2014-12-26 08:57 |
| Reporter | cstrachan1 | Assigned To | |||
| Summary | 0000480: Insert fusion to 2D drawing results in "BSpline curve : # Poles and degree mismatch" | ||||
| Description | Insert fusion to 2D drawing results in "BSpline curve : # Poles and degree mismatch" To reproduce using attached file: Open Drawing workbench Select Fusion028 part Select insert view into page icon Error occurs. | ||||
| Additional Information | Part was downloaded as a step file from vendors CAD resources. http://www.ttabconnectors.com/drawings/ABCIRP/size%2018%20fixed%20socket.zip The part was then fused with bolts and nuts to allow easy rotation and assembly. Ubuntu 11.10 Linux, FreeCAD compiled from svn: updated and compiled 10th Nov 2011. | ||||
Linked against opencascade 6.5.0, Ubuntu 11.10 package 6.5.0.dfsg-2 colin@cs-sis-gcs-laptop:~/Downloads$ ls /usr/lib/libTK* /usr/lib/libTKAdvTools-6.5.0.so /usr/lib/libTKG3d-6.5.0.so /usr/lib/libTKPrim-6.5.0.so /usr/lib/libTKV2d-6.5.0.so /usr/lib/libTKAdvTools.so /usr/lib/libTKG3d.so /usr/lib/libTKPrim.so /usr/lib/libTKV2d.so /usr/lib/libTKBin-6.5.0.so /usr/lib/libTKGeomAlgo-6.5.0.so /usr/lib/libTKPShape-6.5.0.so /usr/lib/libTKV3d-6.5.0.so /usr/lib/libTKBinL-6.5.0.so /usr/lib/libTKGeomAlgo.so /usr/lib/libTKPShape.so /usr/lib/libTKV3d.so /usr/lib/libTKBinL.so /usr/lib/libTKGeomBase-6.5.0.so /usr/lib/libTKService-6.5.0.so /usr/lib/libTKVoxel-6.5.0.so /usr/lib/libTKBin.so /usr/lib/libTKGeomBase.so /usr/lib/libTKService.so /usr/lib/libTKVoxel.so /usr/lib/libTKBinTObj-6.5.0.so /usr/lib/libTKHLR-6.5.0.so /usr/lib/libTKShapeSchema-6.5.0.so /usr/lib/libTKVRML-6.5.0.so /usr/lib/libTKBinTObj.so /usr/lib/libTKHLR.so /usr/lib/libTKShapeSchema.so /usr/lib/libTKVRML.so /usr/lib/libTKBinXCAF-6.5.0.so /usr/lib/libTKIGES-6.5.0.so /usr/lib/libTKShHealing-6.5.0.so /usr/lib/libTKXCAF-6.5.0.so /usr/lib/libTKBinXCAF.so /usr/lib/libTKIGES.so /usr/lib/libTKShHealing.so /usr/lib/libTKXCAFSchema-6.5.0.so /usr/lib/libTKBO-6.5.0.so /usr/lib/libTKLCAF-6.5.0.so /usr/lib/libTKStdLSchema-6.5.0.so /usr/lib/libTKXCAFSchema.so /usr/lib/libTKBool-6.5.0.so /usr/lib/libTKLCAF.so /usr/lib/libTKStdLSchema.so /usr/lib/libTKXCAF.so /usr/lib/libTKBool.so /usr/lib/libTKMath-6.5.0.so /usr/lib/libTKStdSchema-6.5.0.so /usr/lib/libTKXDEIGES-6.5.0.so /usr/lib/libTKBO.so /usr/lib/libTKMath.so /usr/lib/libTKStdSchema.so /usr/lib/libTKXDEIGES.so /usr/lib/libTKBRep-6.5.0.so /usr/lib/libTKMesh-6.5.0.so /usr/lib/libTKSTEP209-6.5.0.so /usr/lib/libTKXDESTEP-6.5.0.so /usr/lib/libTKBRep.so /usr/lib/libTKMesh.so /usr/lib/libTKSTEP209.so /usr/lib/libTKXDESTEP.so /usr/lib/libTKCAF-6.5.0.so /usr/lib/libTKMeshVS-6.5.0.so /usr/lib/libTKSTEP-6.5.0.so /usr/lib/libTKXMesh-6.5.0.so /usr/lib/libTKCAF.so /usr/lib/libTKMeshVS.so /usr/lib/libTKSTEPAttr-6.5.0.so /usr/lib/libTKXMesh.so /usr/lib/libTKCDF-6.5.0.so /usr/lib/libTKNIS-6.5.0.so /usr/lib/libTKSTEPAttr.so /usr/lib/libTKXml-6.5.0.so /usr/lib/libTKCDF.so /usr/lib/libTKNIS.so /usr/lib/libTKSTEPBase-6.5.0.so /usr/lib/libTKXmlL-6.5.0.so /usr/lib/libTKernel-6.5.0.so /usr/lib/libTKOffset-6.5.0.so /usr/lib/libTKSTEPBase.so /usr/lib/libTKXmlL.so /usr/lib/libTKernel.so /usr/lib/libTKOffset.so /usr/lib/libTKSTEP.so /usr/lib/libTKXml.so /usr/lib/libTKFeat-6.5.0.so /usr/lib/libTKOpenGl-6.5.0.so /usr/lib/libTKSTL-6.5.0.so /usr/lib/libTKXmlTObj-6.5.0.so /usr/lib/libTKFeat.so /usr/lib/libTKOpenGl.so /usr/lib/libTKSTL.so /usr/lib/libTKXmlTObj.so /usr/lib/libTKFillet-6.5.0.so /usr/lib/libTKPCAF-6.5.0.so /usr/lib/libTKTObj-6.5.0.so /usr/lib/libTKXmlXCAF-6.5.0.so /usr/lib/libTKFillet.so /usr/lib/libTKPCAF.so /usr/lib/libTKTObj.so /usr/lib/libTKXmlXCAF.so /usr/lib/libTKG2d-6.5.0.so /usr/lib/libTKPLCAF-6.5.0.so /usr/lib/libTKTopAlgo-6.5.0.so /usr/lib/libTKXSBase-6.5.0.so /usr/lib/libTKG2d.so /usr/lib/libTKPLCAF.so /usr/lib/libTKTopAlgo.so /usr/lib/libTKXSBase.so |
Can reproduce on Windows. Seams the B-Spline transfer to SVG seams not to work in that case... |
The same issue is observed with FreeCAD updated to FreeCAD 0.13, Libs: 0.13R5359 and OCC updated to 6.5.2 |
Thinking that the problem may be with rendering the threads cut in the connector, as they would render in bsplines in 2D, to compare I tried to make a 2D view of the M6 bolt I posted in this topic: http://forum.freecadweb.org/viewtopic.php?f=8&t=1222&p=11120&hilit=m6+bolt+thread#p11120 Although it takes a long time to generate the view (at least 3 minutes), it does succeed. |
This doesn't happen any more. Tested with: OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4332 (Git) Branch: master Hash: 33bc596fd8dfcc217531e4d18fcb35537e51b50b Python version: 2.7.6 Qt version: 4.8.5 Coin version: 4.0.0a OCC version: 6.6.0 |
| 2011-11-11 08:54 | cstrachan1 | New Issue | |
| 2011-11-11 09:27 | cstrachan1 | Note Added: 0001273 | |
| 2011-11-21 09:11 |
Note Added: 0001336 | |
| 2011-11-21 09:11 |
| 2011-12-30 08:32 | cstrachan1 | Note Added: 0001523 | |
| 2012-01-16 01:55 | normandc | Note Added: 0001578 | |
| 2012-05-05 18:43 | yorik | Project | FreeCAD => Drawing |
| 2014-12-26 08:57 | wmayer | Note Added: 0005444 | |
| 2014-12-26 08:57 | wmayer | Status | acknowledged => closed |
| 2014-12-26 08:57 | wmayer | Resolution | open => unable to reproduce |
