| 0004829 | Assembly | Bug | public | 2022-01-13 15:45 | 2022-01-17 16:46 |
| Reporter | buteomont | Assigned To | |||
| Platform | Linux | OS | Ubuntu | OS Version | 20.04 |
| Summary | 0004829: Assembly 4 - Can't link to an external part more than once in an Assembly | ||||
| Description | If I create an assembly and insert a link to an external part once, all is well. However, if I insert the same part a second time, it works only if the second part is attached to a different LCS than the first one AND it doesn't have an offset. If I add an offset, the first part moves that same amount. Worse, that part moves in ALL assemblies that link to it, even those in other projects. Worse even still, if I play with the offsets to try to fix it, sometimes FC will crash and disappear. Apparently, adding a link to an external part modifies the external part, which negates the whole reason to use external parts (part reuse). | ||||
| Steps To Reproduce |
| FreeCAD Information | OS: Ubuntu 20.04.3 LTS (GNOME-Flashback:GNOME/gnome-flashback-metacity) Word size of FreeCAD: 64-bit Version: 0.20.26554 (Git) AppImage Build type: Release Branch: (HEAD detached at 817c14b) Hash: 817c14b16af681b06aec7d8c79f744c7a88fa3c3 Python version: 3.9.7 Qt version: 5.12.9 Coin version: 4.0.0 OCC version: 7.5.3 Locale: English/United States (en_US) | ||||
@buteomont : this tracker is for FreeCAD mainstream only. Please report either on addon dedicated tracker (most probably GitHub issue) or on FreeCAD forum (Assembly subforum). Closing. |
