| 0004832 | FreeCAD | Bug | public | 2022-01-16 20:05 | 2022-02-04 16:32 |
| Reporter | chrisdepalma | Assigned To | Kunda1 | ||
| Status | assigned | Resolution | reopened | ||
| Summary | 0004832: Freecad hangs when trying to import a step file | ||||
| Description | I am using latest freecad dev version from 1/16/2022 Freecad hangs when trying to load the step file. It does this on the .19.3 version also. Freecad starts to render but when clicking on the UI even after an hour after starting import, the ui is unresponsive. | ||||
| Steps To Reproduce | Select file import step. Select step file located here: https://github.com/ZeroGDesign/Mercury/blob/main/CAD/Zero%20G%20-%20Mercury%20One.step Freecad will never finish import. This step was i believe generated by Fusion 360. | ||||
| Additional Information | PC is a I7 5820K with 40 GB of ram. | ||||
| FreeCAD Information | OS: Windows 10 Version 2009 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.24267 +99 (Git) Build type: Release Branch: Branch_0.19.3 Hash: 6530e364184ce05ccff39501e175cf2237e6ee4b Python version: 3.8.6+ Qt version: 5.15.2 Coin version: 4.0.1 OCC version: 7.5.3 Locale: English/United States (en_US) | ||||
@chrisdepalma : please report your issues according our reporting guidelines by creating a new topic in our forum. Thx |
Closing since no forum thread was opened. Re-open if needed. |
I added a post on forum as requested. If anybody cares that step files don't load, then you should try the simple repro steps. |
post title: Freecad hangs loading step file. |
Y u no add URL ? |
@Kunda1 Url to github is in the issue. |
url to the forum thread here it is: https://forum.freecad.org/viewtopic.php?f=3&t=65799 OP please read and follow guidelines when doing a bug report |
This ticket has been migrated to GitHub as issue 6311. |
| 2022-01-16 20:05 | chrisdepalma | New Issue | |
| 2022-01-17 16:52 | openBrain | Assigned To | => openBrain |
| 2022-01-17 16:52 | openBrain | Status | new => feedback |
| 2022-01-17 16:52 | openBrain | Note Added: 0016221 | |
| 2022-01-17 16:52 | openBrain | Tag Attached: #post-to-forum | |
| 2022-01-17 16:52 | openBrain | Assigned To | openBrain => |
| 2022-01-19 16:50 | Kunda1 | Assigned To | => Kunda1 |
| 2022-01-19 16:50 | Kunda1 | Status | feedback => closed |
| 2022-01-19 16:50 | Kunda1 | Resolution | open => no change required |
| 2022-01-19 16:50 | Kunda1 | Note Added: 0016227 | |
| 2022-01-30 00:12 | chrisdepalma | Status | closed => feedback |
| 2022-01-30 00:12 | chrisdepalma | Resolution | no change required => reopened |
| 2022-01-30 00:12 | chrisdepalma | Note Added: 0016323 | |
| 2022-01-30 00:13 | chrisdepalma | Note Added: 0016324 | |
| 2022-01-30 00:13 | chrisdepalma | Status | feedback => assigned |
| 2022-01-30 00:51 | Kunda1 | Note Added: 0016325 | |
| 2022-01-30 03:49 | chrisdepalma | Note Added: 0016326 | |
| 2022-01-31 20:39 | adrianinsaval | Note Added: 0016327 | |
| 2022-02-04 16:31 | Kunda1 | Tag Detached: #post-to-forum | |
| 2022-02-04 16:32 | Kunda1 | Tag Attached: #pending-forum |
