| 0000486 | FreeCAD | Bug | public | 2011-11-17 04:56 | 2011-11-18 08:56 |
| Reporter | peepsalot | Assigned To | |||
| Summary | 0000486: Attempting to use spin buttons(up/down arrows) on part properties causes crash | ||||
| Description | Steps to reproduce: Create a box, and select it Click on the Data tab, and put the cursor on a dimension property (Width, Length, or Height). Up down arrows will appear for the currently focused property. Clicking either arrow once instantly crashes FreeCAD The only message I see from the terminal that I started freecad in is "Abnormal program termination..." FreeCAD Ubuntu daily PPA Version 0.12, Revision 4770 (Launchpad) Ubuntu 11.10 Using Gnome Shell desktop environment | ||||
2011-11-17 04:56
I guess it's realted to 0000487. Do you hardware acceleration enabled of your graphics card? |
Do you have qt-at-spi installed? If so remove it. http://code.google.com/p/clementine-player/issues/detail?id=2327 |
This might also be helpful: http://ubuntuforums.org/showthread.php?t=1861605 https://bugs.launchpad.net/ubuntu/+source/quassel/+bug/867925 https://bugreports.qt.nokia.com/browse/QTCREATORBUG-6447 If you need more links just use this with in your favourite search engine: "Creating accessible with different object than the original interface" |
Removing qt-at-spi fixed it for me. |
OK this is a bug in Ubuntu then and not related to FreeCAD. |
| 2011-11-17 04:56 | peepsalot | New Issue | |
| 2011-11-17 04:56 | peepsalot | File Added: FreeCAD.log | |
| 2011-11-17 09:46 | wmayer | Note Added: 0001301 | |
| 2011-11-17 16:40 | wmayer | Note Added: 0001304 | |
| 2011-11-17 16:45 | wmayer | Note Added: 0001305 | |
| 2011-11-18 04:19 | peepsalot | Note Added: 0001306 | |
| 2011-11-18 08:56 | wmayer | Note Added: 0001307 | |
| 2011-11-18 08:56 | wmayer | Status | new => closed |
| 2011-11-18 08:56 | wmayer | Resolution | open => no change required |
| 2011-11-18 08:56 | wmayer | Fixed in Version | => 0.12 |
