| 0000489 | FreeCAD | Feature | public | 2011-11-21 14:49 | 2011-12-10 13:43 |
| Reporter | zappl | Assigned To | wmayer | ||
| Target Version | 0.13 | Fixed in Version | 0.13 | ||
| Summary | 0000489: python console: "RFC"s for even more "rapid" prototyping :-) | ||||
| Description | Hi everybody, FreeCAD is really nice for rapid prototyping geometric algorithms in python. However, in FreeCAD (0.11 ... HEAD@5152), I find the behaviour of the python console quite a bit "unnatural" compared to others (e.g. the native python console, got by calling python at the command shell). * free cursor movement throughout the whole console is confusing * previous input lines including the prompt of the current input line can be changed. This leads easily to syntax errors, e.g. hitting backspace too often might lead to a malformed prompt. * it's not possible to dismiss the current input line but to delete it via backspace. Well, I find myself using this quite often on the linux console ... * accessing the history by Ctrl+Up/Down might be a matter of taste, but for frequent use, I find it too complicated. I'd skip the Ctrl-modifier. * history backward search via considering the current input could really speed up things. e.g. entering "for" + pressing Up, searches the latest history item starting with "for", like "for d in sys.path:". * for calling methods the CallTips are a great feature, but it does not add the needed parentheses. For typing the argument list, it might be handy to place the cursor between those. I played a bit with the source and found some solutions I'd like share as a "RFC" :-). There are two independent patches for the points above: * pyconsole_rfc_keyMap+history.patch - changing the key mapping and adding backward history search * pyconsole_rfc_callCompletion.patch - adds a first approach for a little help on calling methods regards, zappl | ||||
2011-11-21 14:49
Thanks but will be accepted for version 0.13 as discussed on the forum. |
Added in rev 5253. Works great, thank you! (I have put the content of Temporary.hpp to CallTips.cpp) |
| 2011-11-21 14:49 | zappl | New Issue | |
| 2011-11-21 14:49 | zappl | File Added: pyconsole_rfc.zip.zip | |
| 2011-11-21 18:20 | wmayer | Note Added: 0001341 | |
| 2011-11-21 18:20 | wmayer | Assigned To | => wmayer |
| 2011-11-21 18:20 | wmayer | Status | new => assigned |
| 2011-11-21 18:20 | wmayer | Target Version | => 0.13 |
| 2011-12-10 13:43 | wmayer | Note Added: 0001446 | |
| 2011-12-10 13:43 | wmayer | Status | assigned => closed |
| 2011-12-10 13:43 | wmayer | Resolution | open => fixed |
| 2011-12-10 13:43 | wmayer | Fixed in Version | => 0.13 |
