| 0000498 | FreeCAD | Bug | public | 2011-11-27 19:50 | 2015-01-02 14:09 |
| Reporter | peepsalot | Assigned To | wmayer | ||
| Summary | 0000498: "Measure Distance" tool sometimes renders distances inside of solid objects | ||||
| Description | Just noticed from playing around in this tool, that sometimes the marker lines and textual display of the distance are rendered inside of the object, making them impossible to see unless you switch Draw Style to wireframe. | ||||
I should have said, this happened to me when trying to measure a Mesh object directly. Not sure if this happens on Part objects as well. |
Can you provide a simple example that shows this behaviour, please? |
We can use the z-buffer node which suppress hiding for that kind of geometry... |
Or provide a way to tweak the position of the text after creation... A distance property maybe? |
Also possible, but hard to find for the user. |
| 2011-11-27 19:50 | peepsalot | New Issue | |
| 2011-11-30 17:52 | peepsalot | Note Added: 0001378 | |
| 2011-12-01 07:25 | wmayer | Note Added: 0001379 | |
| 2012-12-20 22:17 |
Note Added: 0002729 | |
| 2012-12-20 22:35 | yorik | Note Added: 0002735 | |
| 2012-12-20 22:44 |
Note Added: 0002737 | |
| 2015-01-02 14:09 | wmayer | Changeset attached | => FreeCAD Master master 393d64d5 |
| 2015-01-02 14:09 | wmayer | Assigned To | => wmayer |
| 2015-01-02 14:09 | wmayer | Status | new => closed |
| 2015-01-02 14:09 | wmayer | Resolution | open => fixed |
