| 0000510 | FreeCAD | Feature | public | 2011-12-05 12:32 | 2012-03-13 13:44 |
| Target Version | 0.13 | Fixed in Version | 0.13 | ||
| Summary | 0000510: Arch module - Axes system | ||||
| Description | A tool that allows to create and maintain a system of axes, on which to align structural elements. Needed features: - A 3-dimensions cubic system (for axes in X, Y and Z directions) - A creation tool, that allows to set the number of axes and intervals - Each axis must have distance and angle parameters, so you can change the distance and/or angle of each individual axis - A modification interface to easily change those parameters - Allow snapping to nodes and axes - A couple of methods to return all nodes that satisfy certain criteria (to be used by arch elements) - Different representation modes (to be investigated) - Different modes of SVG output | ||||
Almost done, still needed: - further naming schemes for levels (L0,L1,L2) - different draw styles - svg output - a way to attach Arch components to nodes |
Only one thing missing: - svg output But there is still no proper way to put Arch stuff on a sheet, so... |
Finished in 2a23bd1 - Axes are printable with the Draft Drawing tool |
| 2011-12-05 12:32 | yorik | New Issue | |
| 2011-12-05 12:32 | yorik | Status | new => assigned |
| 2011-12-05 12:32 | yorik | Assigned To | => yorik |
| 2012-01-10 19:34 | yorik | Note Added: 0001554 | |
| 2012-02-05 16:40 | yorik | Note Added: 0001610 | |
| 2012-03-13 13:44 | yorik | Note Added: 0001761 | |
| 2012-03-13 13:44 | yorik | Status | assigned => closed |
| 2012-03-13 13:44 | yorik | Resolution | open => fixed |
| 2012-03-13 13:44 | yorik | Fixed in Version | => 0.13 |
