| 0000515 | Arch | Feature | public | 2011-12-05 12:53 | 2021-02-06 06:28 |
| Summary | 0000515: Arch module - Auto dimension tool | ||||
| Description | A tool that automatically adds dimensions to a set of objects: Select objects, select a point, another point, and the selected objects are measured, with dimensions passing through the 2 points. The result is a "Dimension set" object containing Draft dimensions, where you can change later on which objects are measured, and which "style" of measurement to apply (only biggest exterior dimension, including windows, interior style, etc...) | ||||
| 2011-12-05 12:53 | yorik | New Issue | |
| 2011-12-05 12:53 | yorik | Status | new => assigned |
| 2011-12-05 12:53 | yorik | Assigned To | => yorik |
| 2012-05-04 13:13 | yorik | Project | FreeCAD => Arch |
| 2012-06-12 16:57 | yorik | Target Version | 0.13 => trunk |
| 2012-08-31 11:34 | yorik | Target Version | trunk => 0.14 |
| 2014-01-26 22:37 | yorik | Target Version | 0.14 => |
| 2014-07-06 15:26 | yorik | Target Version | => 0.15 |
| 2015-01-20 23:32 | yorik | Target Version | 0.15 => |
| 2018-01-12 15:09 | yorik | Target Version | => 0.18 |
| 2019-02-15 00:25 | yorik | Target Version | 0.18 => 0.19 |
| 2021-02-06 06:28 | abdullah | Target Version | => 0.20 |
