| 0000521 | FreeCAD | Bug | public | 2011-12-06 02:07 | 2011-12-29 11:32 |
| Reporter | normandc | Assigned To | |||
| Summary | 0000521: Part Design: Pad from sketch on a face - reversed option greyed out in Taskview | ||||
| Description | When padding a sketch mapped to an existing solid's face, the reversed option in the Pad parameters is greyed out. This may be by design (or is it a bug, see next paragraph), but there are cases where you will want to reverse the pad direction because the sketch reaches out of the surface (overhangs), see attached screen capture. Also, this parameter can already be set in the Data tab of the Pad Property View. | ||||
| Additional Information | FreeCAD version 0.12-bzr4851 on Ubuntu 11.10 64-Bit In the attached screen capture, the desired pad direction is down. Forum topic: https://sourceforge.net/apps/phpbb/free-cad/viewtopic.php?f=3&t=1864&p=13809#p13809 | ||||
| 2011-12-06 02:07 | normandc | New Issue | |
| 2011-12-06 02:07 | normandc | File Added: FC_pad_reversed_greyed_out.png | |
| 2011-12-29 11:32 | wmayer | Note Added: 0001517 | |
| 2011-12-29 11:32 | wmayer | Status | new => closed |
| 2011-12-29 11:32 | wmayer | Resolution | open => fixed |
| 2011-12-29 11:32 | wmayer | Fixed in Version | => 0.13 |
