| 0000526 | FreeCAD | Feature | public | 2011-12-08 03:21 | 2012-01-13 14:40 |
| Reporter | momentumv5 | Assigned To | yorik | ||
| Summary | 0000526: view control option | ||||
| Description | One feature that I would always use a lot in Solidworks is the rotating of the view by 90 degrees by using shift+arrow keys. Would this be possible to implement? | ||||
You mean by using the left/right arrow key to rotate around the y-axis (in screen coordinates) and using the up/down arrow key around the x-axis? |
This would mainly be adding 2 GUI tools that take the camera Z axis, and rotate it along that axis by +90° or -90°, right? I think I could try to do that... |
Done! In View->Standard Views and Right-click(context)->Standard views there are now 2 new commands, rotate right and rotate left, where you can set shortcuts as you like... |
| 2011-12-08 03:21 | momentumv5 | New Issue | |
| 2011-12-08 08:10 | wmayer | Note Added: 0001422 | |
| 2011-12-19 13:18 | yorik | Note Added: 0001494 | |
| 2011-12-19 13:18 | yorik | Status | new => assigned |
| 2011-12-19 13:18 | yorik | Assigned To | => yorik |
| 2012-01-13 14:40 | yorik | Note Added: 0001573 | |
| 2012-01-13 14:40 | yorik | Status | assigned => closed |
| 2012-01-13 14:40 | yorik | Resolution | open => fixed |
| 2012-01-13 14:40 | yorik | Fixed in Version | => 0.13 |
