| 0000541 | FreeCAD | Bug | public | 2011-12-15 10:14 | 2012-03-19 20:53 |
| Reporter | gianluki | Assigned To | yorik | ||
| Summary | 0000541: Downgrade function crash | ||||
| Description | I tryed to download and install the last version of Freecad (0.11), first for Win7 and then for Mac. I'm a really beginner and I tryied to follow this tutorial: https://sourceforge.net/apps/mediawiki/ ... t_tutorial. Especially from the "Rectangle" example. Unfortunately, I don't know why, each time I "downgrade" together both rectangle, in both system (Mac,Win), the software crash and close. The PC has Windows7 Prof. 64bit installed, My Mac has OS X 10.6.8 op. system. | ||||
Can you try taking a more recent version from http://sourceforge.net/projects/free-cad/files and see if this bug still happens? |
For MAC: Looks like the version "FreeCAD_i386_R3703.dmg" works for me, I tryed to reinstall again the 0.11 but I always have the same problem. For WIN7:I installed the last version available (0.12), when I select under view/workbench/draft I get this message "Workbench failure", "'module' object has no attribute 'draftToolbar'. |
I really need to install the windows 0.12 version and check if the draft module works ok... I'll do that ASAP |
I finally had a chance to test, and all seems to work fine. Is the bug still there? |
No more feedback, I'll close this issue, don't hesitate to reopen if the problem is still there. |
| 2011-12-15 10:14 | gianluki | New Issue | |
| 2011-12-15 12:30 | yorik | Status | new => assigned |
| 2011-12-15 12:30 | yorik | Assigned To | => yorik |
| 2011-12-15 12:32 | yorik | Note Added: 0001483 | |
| 2011-12-21 08:19 | gianluki | Note Added: 0001504 | |
| 2011-12-21 09:44 | yorik | Note Added: 0001505 | |
| 2012-03-12 20:49 | yorik | Note Added: 0001757 | |
| 2012-03-12 20:49 | yorik | Status | assigned => feedback |
| 2012-03-19 20:52 | yorik | Note Added: 0001800 | |
| 2012-03-19 20:53 | yorik | Status | feedback => closed |
| 2012-03-19 20:53 | yorik | Resolution | open => no change required |
| 2012-03-19 20:53 | yorik | Fixed in Version | => 0.13 |
