| 0000542 | FreeCAD | Feature | public | 2011-12-16 13:52 | 2011-12-29 17:21 |
| Reporter | danielfalck | Assigned To | |||
| Summary | 0000542: request for 'Draft Angle' option for extrusion | ||||
| Description | It would be nice to have the option of adding a 'draft angle' to the extrusion dialog in Part Design and maybe even Part. This is an option in HeeksCAD and I have used it on occasion. Dan Heeks does it like this in 'RuledSurface.cpp' with his BSD licensed code: void CreateExtrusions(const std::list<TopoDS_Shape> &faces_or_wires, std::list<TopoDS_Shape>& new_shapes, const gp_Vec& extrude_vector, double taper_angle, bool solid_if_possible) { try{ for(std::list<TopoDS_Shape>::const_iterator It = faces_or_wires.begin(); It != faces_or_wires.end(); It++) { const TopoDS_Shape& face_or_wire = *It; if(fabs(taper_angle) > 0.0000001) { // make an offset face double distance = tan(taper_angle * Pi/180) * extrude_vector.Magnitude(); bool wire = (face_or_wire.ShapeType() == TopAbs_WIRE); BRepOffsetAPI_MakeOffset offset; if(wire) offset = BRepOffsetAPI_MakeOffset(TopoDS::Wire(face_or_wire)); else continue; // can't do CreateRuledSurface on faces yet offset.Perform(distance); // parallel std::list<TopoDS_Wire> wire_list; wire_list.push_back(TopoDS::Wire(face_or_wire)); wire_list.push_back(TopoDS::Wire(offset.Shape())); gp_Trsf mat; mat.SetTranslation(extrude_vector); BRepBuilderAPI_Transform myBRepTransformation(wire_list.back(),mat); wire_list.back() = TopoDS::Wire(myBRepTransformation.Shape()); TopoDS_Shape new_shape; if(CreateRuledSurface(wire_list, new_shape, solid_if_possible)) { new_shapes.push_back(new_shape); } } else { BRepPrimAPI_MakePrism generator( face_or_wire, extrude_vector ); generator.Build(); new_shapes.push_back(generator.Shape()); } } } catch (Standard_Failure) { Handle_Standard_Failure e = Standard_Failure::Caught(); wxMessageBox(wxString(_("Error making extruded solid")) + _T(": ") + Ctt(e->GetMessageString())); } catch(...) { wxMessageBox(_("Fatal error making extruded solid")); } } | ||||
| Additional Information | I am uploading the a screenshot of the dialog box from HeeksCAD. | ||||
| 2011-12-16 13:52 | danielfalck | New Issue | |
| 2011-12-16 13:52 | danielfalck | File Added: extrusion_dialog.png | |
| 2011-12-16 13:53 | danielfalck | File Added: extruded_part.png | |
| 2011-12-29 17:21 | wmayer | Note Added: 0001519 | |
| 2011-12-29 17:21 | wmayer | Status | new => closed |
| 2011-12-29 17:21 | wmayer | Resolution | open => fixed |
| 2011-12-29 17:21 | wmayer | Fixed in Version | => 0.13 |
