| 0000543 | FreeCAD | Bug | public | 2011-12-16 15:06 | 2011-12-16 20:05 |
| Reporter | danielfalck | Assigned To | yorik | ||
| Summary | 0000543: objects that don't have a shape prevent Draft functions from working | ||||
| Description | I ran across this while playing with my own Point class and then found it also happens when using the Draft wb to create objects. 1. with the Draft wb, create some text on the screen 2. try to create a line or rectangle- sometimes it only happens after trying to create more than one object- try creating several rectangles. 3. at some point the snap tracker or snapping seems to give up and it's not possible to create geometry any more. 4. This code appears in the terminal: <type 'exceptions.AttributeError'> Traceback (most recent call last): File "/home/danfalck/cadcam/freecad/Mod/Draft/DraftTools.py", line 756, in action point,ctrlPoint = getPoint(self,arg,mobile=True) File "/home/danfalck/cadcam/freecad/Mod/Draft/DraftTools.py", line 123, in getPoint point = snapPoint(target,point,args["Position"],hasMod(args,MODSNAP)) File "/home/danfalck/cadcam/freecad/Mod/Draft/DraftSnap.py", line 601, in snapPoint edges = ob.Shape.Edges AttributeError: 'App.DocumentObject' object has no attribute 'Shape' I can't create any more geometry until I delete all text objects | ||||
| 2011-12-16 15:06 | danielfalck | New Issue | |
| 2011-12-16 16:43 | yorik | Status | new => assigned |
| 2011-12-16 16:43 | yorik | Assigned To | => yorik |
| 2011-12-16 20:05 | yorik | Note Added: 0001486 | |
| 2011-12-16 20:05 | yorik | Status | assigned => closed |
| 2011-12-16 20:05 | yorik | Resolution | open => fixed |
| 2011-12-16 20:05 | yorik | Fixed in Version | => 0.13 |
