| 0000555 | FreeCAD | Feature | public | 2011-12-30 12:04 | 2012-01-01 11:47 |
| Reporter | microtorch | Assigned To | |||
| Summary | 0000555: 3D navigation using a two-button laptop touchpad | ||||
| Description | Hi all, I am using FreeCAD v0.12 revision 5284 on an MSI M670 laptop running Vista 32bit. I would like to be able to use FreeCAD with the built-in touchpad rather than having to use a separate mouse. The M670 touchpad has two buttons and a scroll area to the right so zoom is fine. However, it does not have a way to do middle mouse button click or hold. Holding Left and Right buttons down together does not work, so I am really stuck. Could you consider adding a specific 3D Navigation option for this type of Touchpad? My suggestion on control mapping is as follows. Select: Left mouse button. Pan: Holding shift down whilst moving mouse causes view to pan. Rotate: Holding Shift+Ctrl down whilst moving the mouse causes view to rotate. Zoom: Scroll up = Zoom-in, scroll down = Zoom-out. Rob | ||||
Using a touch pad is the same as having a two-button mouse. To have full control switch to Inventor navigation and use this setting: Rotating == Left mouse button Panning == Shift + Left mouse button Selection == Ctrl + Left mouse button For zooming in/out our default is Ctrl + +/-. However, under Tools>Customize you can use PgUp/PgDn instead. Alternatively, I'll also implement Shift+Ctrl+Right mouse button for zooming. For CAD and Blender navigation this is already used but not for Inventor. |
Sorry, I should have mentioned that I already tried the Inventor navigation out. The problem is it doesn't allow you to select additional objects from the 3D view (because Ctrl + Left Mouse Button is now Select). My suggestion retains the use of Left Mouse Button for selection and Ctrl + Left Mouse Button to add to the selection. There is no problem with zooming (on my touchpad at least) so perhaps you could reconsider my original suggestion. |
So, if I got you right the only problem you have is the multi-selection. That's indeed not possible with the Inventor style. Your feature request should be pretty simple to implement but I just wanted to point out that with the current implementation (besides multi-selection) everything can be done with the Inventor style already. |
Yes, I was using the Inventor navigation for a while, but the multi-selection was the show-stopper. |
Added in rev 5373 Additional alternatives: Rotate: ALT + move Zoom: CTRL + SHIFT + LMB + move |
| 2011-12-30 12:04 | microtorch | New Issue | |
| 2011-12-31 13:45 | wmayer | Note Added: 0001525 | |
| 2011-12-31 14:33 | wmayer | Note Edited: 0001525 | |
| 2011-12-31 14:34 | wmayer | Note Edited: 0001525 | |
| 2011-12-31 14:53 | microtorch | Note Added: 0001526 | |
| 2011-12-31 16:35 | wmayer | Note Added: 0001527 | |
| 2011-12-31 16:54 | microtorch | Note Added: 0001528 | |
| 2012-01-01 11:47 | wmayer | Note Added: 0001531 | |
| 2012-01-01 11:47 | wmayer | Status | new => closed |
| 2012-01-01 11:47 | wmayer | Resolution | open => fixed |
| 2012-01-01 11:47 | wmayer | Fixed in Version | => 0.13 |
