| 0000569 | FreeCAD | Bug | public | 2012-01-10 20:41 | 2012-05-04 12:56 |
| Summary | 0000569: couple draft bugs | ||||
| Description | Hi, I really like draft offset - occ style. Great feature. However, I noticed some bugs: 1 - this seems to work only on polyline. I can not make it to work on single line or arc. 2 - Even if I can make offset on polyline, I can not make face of it. 3 - When I make offset on polyline, converting it to sketch is badly. regards, Petar | ||||
Okay, I'll look into it, should be solvable... |
A bit of additional info ater testing: 1. OCC seems to have a problem making offsets of 1-edge wires. This indeed includes lines and arcs. Not too sure if there is a solution but will look into it. 2. Make faces works for me: Select an offsetted wire, press the Draft Upgrade button, then put it in Flat Lines mode (Shift+Space) 3. Indeed, converting it into a sketch has arcs inversions. I'll fix that first... |
2 works here too. I did not know I have to switch to wireframe manually. |
point 3 is now fixed |
this seems to be bad again. I can not even use OCC style offset anymore. |
fixed now. Still couldn't find a solution for problem #1, though... |
I have just cloned from git (I used to do svn up until now, but since you fixed this I wanted to check). I can not even place wire nor polyline now. EDIT: I think this was because I tried first time to use git. let me try once more |
Here all seems to work fine... Can you explain better what's wrong? |
Okay, there is a bug indeed, but it's another problem in the vector API... |
Okay I finally discovered the problem... For OCC to make its offset, it must know what is th normal direction of a wire (so the offset goes in the plane perpendicular to that normal). In a wire made of only one line segment, there is no way to know what the normal is, so there is no way to do the offset. I'll close this bug since it is not directly solvable, in the future we can try to make ourselves to some alternative solution... |
| 2012-01-10 20:41 | pperisin | New Issue | |
| 2012-01-11 13:03 | yorik | Status | new => assigned |
| 2012-01-11 13:03 | yorik | Assigned To | => yorik |
| 2012-01-11 13:03 | yorik | Note Added: 0001558 | |
| 2012-01-11 14:10 | yorik | Note Added: 0001559 | |
| 2012-01-11 14:28 | pperisin | Note Added: 0001560 | |
| 2012-01-12 12:58 | yorik | Note Added: 0001568 | |
| 2012-03-12 10:08 | pperisin | Note Added: 0001751 | |
| 2012-03-12 12:28 | yorik | Note Added: 0001752 | |
| 2012-03-12 14:13 | pperisin | Note Added: 0001753 | |
| 2012-03-12 14:28 | pperisin | Note Edited: 0001753 | |
| 2012-03-12 14:29 | pperisin | Note Edited: 0001753 | |
| 2012-03-12 14:30 | yorik | Note Added: 0001754 | |
| 2012-03-12 20:48 | yorik | Note Added: 0001756 | |
| 2012-05-04 12:56 | yorik | Note Added: 0002011 | |
| 2012-05-04 12:56 | yorik | Status | assigned => closed |
| 2012-05-04 12:56 | yorik | Resolution | open => not fixable |
| 2012-05-04 12:56 | yorik | Fixed in Version | => 0.13 |
