| 0000583 | FreeCAD | Feature | public | 2012-02-01 16:37 | 2012-03-13 16:20 |
| Target Version | 0.13 | Fixed in Version | 0.13 | ||
| Summary | 0000583: Make the Draft rectangle not depend on coin's Simage module | ||||
| Description | The Draft rectangle can have an image as texture mapping. However coin uses the Simage module to load an image file, and that module is not present on some systems. The solution would be to load the image with Qt, then pass it as a string to the coin SoTexture node, bypassing the coin file load. | ||||
| Additional Information | from http://sourceforge.net/apps/phpbb/free-cad/posting.php?mode=reply&f=10&t=2195 | ||||
| 2012-02-01 16:37 | yorik | New Issue | |
| 2012-02-01 16:37 | yorik | Status | new => assigned |
| 2012-02-01 16:37 | yorik | Assigned To | => yorik |
| 2012-03-13 16:20 | yorik | Note Added: 0001767 | |
| 2012-03-13 16:20 | yorik | Status | assigned => closed |
| 2012-03-13 16:20 | yorik | Resolution | open => fixed |
| 2012-03-13 16:20 | yorik | Fixed in Version | => 0.13 |
