| 0000060 | FreeCAD | Bug | public | 2009-12-14 18:46 | 2010-04-07 08:29 |
| Reporter | supiik | Assigned To | |||
| Product Version | 0.9 | ||||
| Summary | 0000060: Open document dialog does not filter files correctly | ||||
| Description | Hi, If I want to open fcstd document I saved last time Open Document dialog does not display them. I would expect that I will see this file when Supported formats or FreeCAD document is selected in file filter. But it is not. Only way how to show this kind of file is to choose All files. Please correct me if I am doing something wrong. Best regards Peter | ||||
On Windows I see the FreeCAD project files. I guess you use some flawor of Linux. We need more information to confirm the bug! |
Hi, yes, I am using Ubuntu 9.10. What kind of confirmation do you need? Is screenshot enough? Please let me know how to get more info to resolve this problem. Best regards Peter |
I mean to check my self ;) Not I disbelieving you, but only an error we can reproduce some how we can track down and fix! Ubuntu I can check! Jürgen |
This is actually a bug in Qt because the file filters are case-sensitive and seems to be fixed in version 4.5.3 -- I have tested it on Debian testing and there it works. |
I tested on debian testing and ubuntu 9.10, indeed on debian it works, and on ubuntu not. And indeed debian uses qt 4.5.3 and ubuntu9.10 uses qt 4.5.2... |
If there is no work around ( I cant think of one ) I would close the bug and wait till Ubuntu 10.4 with a newer QT Version .... |
This is clearly a Qt bug. So, let's wait for a newer Qt version (>= 4.5.3). |
| 2009-12-14 18:46 | supiik | New Issue | |
| 2009-12-15 09:33 |
Note Added: 0000070 | |
| 2009-12-15 09:33 |
Status | new => feedback |
| 2009-12-15 09:53 | unauthenticated | Note Added: 0000071 | |
| 2009-12-15 16:17 |
Note Added: 0000072 | |
| 2009-12-15 20:21 | wmayer | Note Added: 0000073 | |
| 2010-02-07 13:53 | yorik | Note Added: 0000167 | |
| 2010-02-07 16:34 |
Note Added: 0000169 | |
| 2010-04-07 08:29 | wmayer | Note Added: 0000192 | |
| 2010-04-07 08:29 | wmayer | Status | feedback => closed |
| 2010-04-07 08:29 | wmayer | Resolution | open => won't fix |
