0000605FreeCADBugpublic2012-03-01 13:43
Reporterj-dowsett Assigned To
PrioritynormalSeverityminorReproducibilitysometimes
Product Version0.12
Fixed in Version0.13
Summary0000605: Python console - removing drawing view removes remaining views from tree
DescriptionSometimes removing a view from a drawing containing two or more views will also remove the remaining view from the document tree, though it remains as an object (by which I mean it's accessible from the python console).
*seems sensitive - do not expand the page tree after adding views*
Open a part.
Switch to drawing workbench.
Insert a drawing page.
Add a view (will be called 'View').
Add a second view ('View001').
In the python console execute - App.ActiveDocument.removeObject('View001')
The 'expansion' + sign thingy next to the page will disappear - View cannot be accessed from the document tree.
Typing 'App.ActiveDocument.V' then autocomplete shows that 'View' still exists.
Expanding the page tree after adding views but before removing them prevents this disappearance.
2012-02-16 16:06
administrator   ~0001636
What is your OS and which Qt version? Testing this with Win7/Qt4.5.3 there is no problem.
j-dowsett
2012-02-16 20:05
reporter   ~0001637
Sorry, that was slack.
My system is Ubuntu 10.04, Qt 4.6.2, FreeCAD is the most recent from PPA (it doesn't list a version number in the about dialog), also a build from git of a day or two old shows the same behaviour.
However: I've also just tried it on Windows Vista, FreeCAD 0.12 / 5284, Qt 4.5.2, and I can't replicate it here.
I realise it's a minor bug and typically wouldn't arise, but it crops up with the OrthoViews gui, and will do so even more on the new one I'm working on - it now creates four views, and a fair proportion of the time I guess a user will only want three, so it will delete one on exit.
2012-03-01 13:43
administrator   ~0001696
That's a Qt bug. I checked it on Ubuntu 11.04 and there it works perfectly but I can confirm this issue on 10.04. But there is a trick: if you collapse and expand the document item the missing indicator re-appears.
2012-02-15 20:08 j-dowsett New Issue
2012-02-16 16:06 wmayer Note Added: 0001636
2012-02-16 20:05 j-dowsett Note Added: 0001637
2012-03-01 13:43 wmayer Note Added: 0001696
2012-03-01 13:43 wmayer Status new => closed
2012-03-01 13:43 wmayer Resolution open => not fixable
2012-03-01 13:43 wmayer Fixed in Version => 0.13
