0000615FreeCADBugpublic2013-07-01 09:44
Reportererikevenson Assigned To
Product Version0.12
Fixed in Version0.14
Summary0000615: Cannot Import Part Module from Command Line
DescriptionFreeCAD is unable to import the Part module when run from the command line on Mac OS X 10.7.3.
Additional InformationMonolith:Desktop eevenson$ /Applications/FreeCAD.app/Contents/MacOS/FreeCAD -c
FreeCAD 0.13, Libs: 0.13RUnknown
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2011
[FreeCAD Console mode <Use Ctrl-D (i.e. EOF) to exit.>]
>>> import FreeCAD
>>> import Part
  File "<stdin>", line 1, in <module>
ImportError: dlopen(/Applications/FreeCAD.app/Contents/Mod/Part/Part.so, 2): Library not loaded: libTKernel.2.dylib
  Referenced from: /Applications/FreeCAD.app/Contents/Mod/Part/Part.so
  Reason: image not found
2012-02-29 10:42
administrator   ~0001684
Obviously you run a pretty recent version of FreeCAD under Mac. Did you build the binaries yourself or did you install a pre-built package?
Please note, that nobody of the FreeCAD developers have a Mac and thus we cannot guarantee for the quality of such packages. It might be possible that the package builder forgot to include some modules or the Mac version it was built is different to yours.
From the error description it seems that the Part module cannot load a file from the OpenCascade (OCC) library. So, please check if in the FreeCAD package you find this file somewhere. If not then you very like have to install also the OCC library.
Since the OCE project is a fork of OCC and should still be binary compatible you can get a Mac version from here: https://github.com/tpaviot/oce/downloads
erikevenson
2012-02-29 22:28
reporter   ~0001691
I installed a pre-built package. I understand that the Mac packages are unsupported. I installed the OCE library and still have not been able to get things to work.
Thanks for your help in any case -- I will probably try to run my scripts on a Linux VM instead.
2012-03-01 08:26
administrator   ~0001692
For Part.so you should check which other libraries this depends on. Under Mac the tool is "otool". Since it still doesn't find the OCC files you possibly have to set an environment variable. Under Linux this is LD_LIBRARY_PATH but I don't know what's the counterpart on Mac.
2013-03-03 13:32
administrator   ~0002962
Degrade to Minor severity because it doesn't seem to be a FreeCAD problem but how it was built by the package maintainer. Maybe we should even close it...
2013-07-01 09:44
administrator   ~0003309
sorry, but there is nothing we can do.
2012-02-28 23:56 erikevenson New Issue
2012-02-29 10:42 wmayer Note Added: 0001684
2012-02-29 22:28 erikevenson Note Added: 0001691
2012-03-01 08:26 wmayer Note Added: 0001692
2012-05-05 18:01 yorik Status new => feedback
2013-03-03 13:32 wmayer Note Added: 0002962
2013-03-03 13:32 wmayer Severity block => minor
2013-07-01 09:44 wmayer Note Added: 0003309
2013-07-01 09:44 wmayer Status feedback => closed
2013-07-01 09:44 wmayer Resolution open => not fixable
2013-07-01 09:44 wmayer Fixed in Version => 0.14
