| 0000618 | FreeCAD | Bug | public | 2012-03-03 17:55 | 2012-03-11 09:05 |
| Reporter | djreichel | Assigned To | |||
| Summary | 0000618: View PartDesign Workbench fails: 'module' object has no attribute 'makeFilletArc' | ||||
| Description | commit 5145acf1e4b45111c3cab12311c62c0026cd4f0f Author: tanderson <blobfish[at]gmx.com> Date: Thu Mar 1 16:58:56 2012 -0500 built on Fedora 16 | ||||
| Additional Information | I was able to suppress this message and load PartDesign by editing the file: /Mod/PartDesign/__init__.py to remove the makeFilletArc reference. cat __init__.py import PartDesign #makeFilletArc = PartDesign.makeFilletArc PartDesign.makeFilletArc is not available to scripting. I'm still learning what works in this build, but if it's helpful to know, I *can* see Part.makeCircle from a python script both in the Gui Python Console and from scripts run through FreeCADCmd. | ||||
Did you build with automake or cmake? When you enter: import PartDesign you only load the __init__.py file. That's why we do the assignment makeFilletArc = PartDesign.makeFilletArc So that you can do: import PartDesign PartDesign.makeFilletArc(...) Without this you have to do: import PartDesign PartDesign.PartDesign.makeFilletArc(..) or from PartDesign import PartDesign PartDesign.makeFilletArc(...) Since you get an error here it seems that the file PartDesign.so cannot be found by Python. Or can you do this: from PartDesign import PartDesign as pd pd.__file__ |
Build was with Automake. I rebuilt with: commit 0d782797a082ebdba039530861abab9a9d8fb6a5 Author: wmayer <wmayer(a)users.sourceforge.net> Date: Sat Mar 3 18:24:49 2012 +0100 And the problem is gone. I had made a test script: [dennis@verne ~]$ cat test.py import Part, PartDesign makeCircle=Part.makeCircle print "Here we Die" makeFilletArc=PartDesign.makeFilletArc quit() Running in FreeCADCmd, formerly it would fail at: makeFilletArc=PartDesign.makeFilletArc I understand from your above comment that this test's failure did not address the question of whether or not PartDesign.so was found... Unfortunately I do not have the bad build to test your suggestion. from PartDesign import PartDesign as pd pd.__file__ I *did* try: from PartDesign import makeFilletArc and the message was the same <module>,etc.. However I should also mention that while this was not working I could browse in the Python Console object completion mode and saw: PartDesign.__builtins__, __doc__, and the rest, but there was not a PartDesign.makeFilletArc. This suggest to me that PartDesign was found by FreeCAD, but the makeFilletArc method was not visible. I'm not sure if this is a "can not reproduce" or a "problem solved" |
I have done some tests: If I delete the PartDesign.so (PartDesign.pyd under Windows) the "import PartDesign" failed with the same error you posted. If I now comment out the second line in __init__.py it works. So, I conclude that on the previous version the PartDesign.so file was missing. I think this issue can be regarded as resolved. What do you think? |
To check out some other issues, I built the FreeCad 0.12 tarball that's posted on FreeCAD's source code download page: freecad-0.12.5284.tar.gz 2012-01-04 48.4 MB, and commented out import PartDesign's #makeFilletArc = PartDesign.makeFilletArc and did the following test to repicate this bug. [dennis@verne .FreeCAD]$ freecad-0.12-Cmd FreeCAD 0.12, Libs: 0.12R5382 (c) Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2011 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## [FreeCAD Console mode <Use Ctrl-D (i.e. EOF) to exit.>] >>> from PartDesign import PartDesign as pd pd.__file__>>> '/usr/lib/freecad-0.12/PartDesign/__init__.py' >>> pd.makeFilletArc Traceback (most recent call last): File "<stdin>", line 1, in <module> AttributeError: 'module' object has no attribute 'makeFilletArc' >>> Somehow this *has* been corrected between 2012-01-04 and the present. |
Missing reference to FilletArc.py in Makefile.am [freecad@verne git]$ diff -uNr freecad-0.12/ freecad-local/ diff -uNr freecad-0.12/src/Mod/PartDesign/Scripts/Makefile.am freecad-local/src/Mod/PartDesign/Scripts/Makefile.am --- freecad-0.12/src/Mod/PartDesign/Scripts/Makefile.am 2012-03-04 11:59:01.576207870 -0500 +++ freecad-local/src/Mod/PartDesign/Scripts/Makefile.am 2012-03-10 18:35:13.113324871 -0500 @@ -2,12 +2,13 @@ datadir = $(prefix)/Mod/PartDesign/Scripts data_DATA = \ __init__.py \ - Gear.py \ DistanceBolt.py \ - Epitrochoid.py \ - RadialCopy.py \ - Parallelepiped.py \ - Spring.py + Epitrochoid.py \ + FilletArc.py \ + Gear.py \ + Parallelepiped.py \ + RadialCopy.py \ + Spring.py EXTRA_DIST = \ $(data_DATA) [freecad@verne git]$ |
Added in git bd24d5beaf312b26822cd01122343249b3a2811b (0.13) |
| 2012-03-03 17:55 | djreichel | New Issue | |
| 2012-03-03 18:24 | wmayer | Note Added: 0001703 | |
| 2012-03-03 19:00 | djreichel | Note Added: 0001704 | |
| 2012-03-03 19:15 | djreichel | Note Edited: 0001704 | |
| 2012-03-03 20:41 | wmayer | Note Added: 0001705 | |
| 2012-03-08 03:37 | djreichel | Note Added: 0001722 | |
| 2012-03-08 06:22 | wmayer | Status | new => closed |
| 2012-03-08 06:22 | wmayer | Resolution | open => no change required |
| 2012-03-08 06:22 | wmayer | Fixed in Version | => 0.13 |
| 2012-03-10 22:47 | djreichel | Note Added: 0001737 | |
| 2012-03-10 22:47 | djreichel | Status | closed => feedback |
| 2012-03-10 22:47 | djreichel | Resolution | no change required => reopened |
| 2012-03-11 09:05 | wmayer | Note Added: 0001741 | |
| 2012-03-11 09:05 | wmayer | Status | feedback => closed |
| 2012-03-11 09:05 | wmayer | Resolution | reopened => fixed |
