| 0000063 | FreeCAD | Bug | public | 2010-01-08 16:44 | 2010-04-10 09:58 |
| Product Version | 0.9 | ||||
| Summary | 0000063: Crash in Robot module | ||||
| Description | When creating a robot object and a trajectory without filling up, select both and run the simulation the app crashes. | ||||
I use it at the moment all the time... I need more information. You have the latest trunk? |
1. New document 2. Insert Robots > Kuka IR500 3. Create trajectory 4. Select both and run Simulate a trajectory => Crash in Trajectory_Composite::Pos() because "traj = vt[vt.size()-1];" is wrong if vt is empty. The methods * Trajectory::getLength * Trajectory::getDuration * Trajectory::getVelocity have probably the same problem. |
Ahh, I never tried to simulate a empty trajectory ;) I fix it! Thanks |
So far there exists no method to query the size of "vt" but checking the path length with pcTrajectory->GetPath()->PathLength() does pretty much the same. So, if the length is 0 an empty placement can be returned. The implementation can look like this: Placement Trajectory::getPosition(double time)const { if (pcTrajectory && pcTrajectory->GetPath()->PathLength() > 0.0) return Placement(toPlacement(pcTrajectory->Pos(time))); else return Placement(); } The same applies to the other questionable methods I have listed. |
fixed with 2851 |
This bug is still not properly fixed. When inserting exact one position the crash sill occurs. |
fixed with 3079 |
| 2010-01-08 16:44 | wmayer | New Issue | |
| 2010-01-08 16:44 | wmayer | Status | new => assigned |
| 2010-01-08 16:44 | wmayer | Assigned To | => Jriegel |
| 2010-01-08 16:46 |
Note Added: 0000129 | |
| 2010-01-08 16:46 |
Status | assigned => feedback |
| 2010-01-08 20:29 | wmayer | Note Added: 0000130 | |
| 2010-01-09 08:25 |
Note Added: 0000131 | |
| 2010-01-09 09:25 | wmayer | Note Added: 0000132 | |
| 2010-01-12 18:35 |
Note Added: 0000144 | |
| 2010-01-12 18:35 |
Status | feedback => closed |
| 2010-01-12 18:35 |
Resolution | open => fixed |
| 2010-01-17 12:29 | wmayer | Note Added: 0000150 | |
| 2010-01-17 12:29 | wmayer | Status | closed => assigned |
| 2010-01-17 12:29 | wmayer | Resolution | fixed => reopened |
| 2010-04-08 09:44 |
Note Added: 0000200 | |
| 2010-04-08 09:44 |
Status | assigned => resolved |
| 2010-04-08 09:44 |
Resolution | reopened => fixed |
| 2010-04-10 09:58 | wmayer | Status | resolved => closed |
