| 0000645 | FreeCAD | Bug | public | 2012-03-17 08:25 | 2012-04-10 16:32 |
| Reporter | peepsalot | Assigned To | |||
| Summary | 0000645: Mesh.Mesh returns empty mesh when provided integers | ||||
| Description | I was experimenting with mesh scripting, and made a simple script for displaying a "handmade" tetrahedron. But when I ran the script the mesh was not displayed in the document. It took me quite a bit of time to figure out what was going on, but it appears that passing integers for vertex coordinates results in an empty mesh. Once I rewrote this to pass in floats, it worked as expected. Attached is a script with two methods, the first provides a list of faces to Mesh.Mesh in the form of integers, and the second in the form of floats. The first one results in an empty mesh, while the second succeeds. Results: Mesh: [0 Faces, 0 Edges, 0 Points] Mesh: [4 Faces, 6 Edges, 4 Points] Expected: Mesh should be able to accept integers as input, or at least throw a warning/error or something if it fails to add these vertices. | ||||
| Additional Information | Ubuntu 11.10 64 bit FreeCAD 0.13 git 0674 | ||||
| 2012-03-17 08:25 | peepsalot | New Issue | |
| 2012-03-17 08:25 | peepsalot | File Added: MeshTest.py | |
| 2012-04-10 16:32 | wmayer | Note Added: 0001923 | |
| 2012-04-10 16:32 | wmayer | Status | new => closed |
| 2012-04-10 16:32 | wmayer | Resolution | open => fixed |
| 2012-04-10 16:32 | wmayer | Fixed in Version | => 0.13 |
