| 0000647 | FreeCAD | Bug | public | 2012-03-18 22:42 | 2012-03-19 20:50 |
| Reporter | djreichel | Assigned To | yorik | ||
| Summary | 0000647: Draft Module configuration settings need to be applied before Construction Mode works | ||||
| Description | Ubuntu 10.04 FreeCAD ppa Version: 0.13.0674 (Git) Branch: master Hash: 6a77635bdbb0fea476ab268234bea8d0cbe9506c And git dd629436486f4f401a23c37923bef0108f382921 on Fedora 16 With a new installation, until the user does: Edit->Preferences->Apply the Construction mode functionality is not available. | ||||
Also, Draft snap to center did not work until preferences were applied as described above. |
Hm strange, I'll look into it |
Fixed in commit 343bc96 I set a couple of defaults for the draft module, to be set at first initialization. I might have forgotten one or another, so please reopen this issue if needed. |
| 2012-03-18 22:42 | djreichel | New Issue | |
| 2012-03-18 22:59 | djreichel | Note Added: 0001791 | |
| 2012-03-19 15:31 | yorik | Note Added: 0001792 | |
| 2012-03-19 15:31 | yorik | Status | new => assigned |
| 2012-03-19 15:31 | yorik | Assigned To | => yorik |
| 2012-03-19 20:50 | yorik | Note Added: 0001799 | |
| 2012-03-19 20:50 | yorik | Status | assigned => closed |
| 2012-03-19 20:50 | yorik | Resolution | open => fixed |
| 2012-03-19 20:50 | yorik | Fixed in Version | => 0.13 |
