| 0000658 | FreeCAD | Patch | public | 2012-04-01 15:57 | 2012-04-10 15:23 |
| Reporter | djreichel | Assigned To | |||
| Summary | 0000658: Automake lacks option to build Mods: Assembly and Cam | ||||
| Description | Unified Patch attached below: | ||||
| Additional Information | Semi-related issues are these compile errors using automake system if the corresponding module is enabled. # make[5]: Entering directory `/home/freecad/rpmbuild/BUILD/freecad-0.12/src/Mod/Assembly/Gui' # make[5]: *** No rule to make target `AssemblyView.h', needed by `moc_AssemblyView.cpp'. Stop. # Command.cpp:43:42: fatal error: Inventor/nodes/SoAnnotation.h: No such file or directory compilation terminated. # make[5]: *** [libSandboxGui_la-Command.lo] Error 1 # make[5]: Leaving directory `/home/freecad/rpmbuild/BUILD/freecad-0.12/src/Mod/Sandbox/Gui' # In file included from AppCamPy.cpp:92:0: # best_fit.h:36:26: fatal error: SMESH_Mesh.hxx: No such file or directory # compilation terminated. # make[5]: *** [libCam_la-AppCamPy.lo] Error 1 # make[5]: Leaving directory `/home/freecad/rpmbuild/BUILD/freecad-0.12/src/Mod/Cam/App' # Command.cpp: In constructor 'Cmd_TEMPLATE_Test::Cmd_TEMPLATE_Test()': # Command.cpp:51:5: error: 'iAccel' was not declared in this scope # make[6]: *** [lib_TEMPLATE_Gui_la-Command.lo] Error 1 # make[6]: Leaving directory `/home/freecad/rpmbuild/BUILD/freecad-0.12/src/Tools/_TEMPLATE_/Gui' I will attempt to provide solutions for these issues. | ||||
2012-04-01 15:57
Attached patch for /src/Mod/Assembly/Resources/Makefile.am adds recent translations and correctly references Assembly module instead of Drawing module allowing Assembly module to build with automake. freecad-assembly-automake.patch |
2012-04-07 20:50
2012-04-10 01:17
Please disregard file: freecad-assembly-automake.patch [^] (2,266 bytes) 2012-04-07 22:50 Instead: freecad-assembly-cam-automake.patch [^] (7,660 bytes) 2012-04-10 03:17 includes contents of previously submitted patch and allows modules assembly and cam to build with automake. |
The patch was applied with some little modifications. It is bad practise to include Qt headers like this: #include <QtCore/QString> because it doesn't work on all platforms like Apple when using the framework stuff. It should be #include <QString> and the the INCLUDE path should be set accordingly. |
| 2012-04-01 15:57 | djreichel | New Issue | |
| 2012-04-01 15:57 | djreichel | File Added: automake_modules.patch | |
| 2012-04-07 20:49 | djreichel | Note Added: 0001905 | |
| 2012-04-07 20:50 | djreichel | File Added: freecad-assembly-automake.patch | |
| 2012-04-10 01:17 | djreichel | File Added: freecad-assembly-cam-automake.patch | |
| 2012-04-10 01:24 | djreichel | Note Added: 0001914 | |
| 2012-04-10 15:23 | wmayer | Note Added: 0001917 | |
| 2012-04-10 15:23 | wmayer | Status | new => closed |
| 2012-04-10 15:23 | wmayer | Resolution | open => fixed |
| 2012-04-10 15:23 | wmayer | Fixed in Version | => 0.13 |
