| 0000662 | FreeCAD | Bug | public | 2012-04-04 05:04 | 2012-12-20 21:59 |
| Summary | 0000662: Another tab close issue | ||||
| Description | Hi, Issue with two tabs closed is fixed https://sourceforge.net/apps/mantisbt/free-cad/view.php?id=636 , but there is one more issue with tab close I have. When I have multiple tabs opened, and I close all but one of them, so that there is only one opened, I get the view like on attached picture. Regards Petar | ||||
| Additional Information | OpenSUSE 12.1 compiled from git on 4.4.2012 | ||||
2012-04-04 05:04
That's some kind of OpenGL glitches. So, we can't do anything on that. |
OK, However, I would leave it opened, to see if someone else is having the same issues. I have proprietary NVidia drivers installed Graphic card is NVidia GeForce 315M, on Toshiba C660 Regards, Petar |
The two tabs close issue on Fedora 16 still remains. Version: 0.13.0817 (Git) Branch: master Hash: 238750d3e47ccae90ce587d7b249cced30e02dfa For instance, I am working on a document and click X to close the tab. I will be prompted to save yes/no/cancel. I select cancel and the dialog appears again. The close document event is triggered twice. Another example, I launch Freecad and File-New Document twice. I will close one tab and both tabs will be removed. Then there is an unexpected behavior relating to opening a document. Same as above I create two new/unnamed documents. Then I will File->Open an existing document. At this time one of the new/unnamed document tabs will be replaced with a tab for the document that has been opened. |
If you build the sources directly you can check MainWindow::tabCloseRequested(). This shouldn't be called for Qt 4.8. See also the lines: #if QT_VERSION < 0x040800 connect(tab, SIGNAL(tabCloseRequested(int)), this, SLOT(tabCloseRequested(int))); #endif > Then there is an unexpected behavior relating to opening a document. Same as above I create two new/unnamed documents. Then I will File->Open an existing document. At this time one of the new/unnamed document tabs will be replaced with a tab for the document that has been opened. No, that's not a bug. That's the intended behaviour but I don't like it either. |
My note: djreichel (reporter) 2012-04-04 17:57 Contains errors - the tab close issue was in fact corrected, but my git repository was not merging correctly (git pull origin was run from an automated build script with the default dir ../my_git_repo_dir. The git progress output looked fine, but the patched files were not placed in the proper location - in case anyone was wondering wtf..) =============== REPORTED IN ERROR ===================== The two tabs close issue on Fedora 16 still remains. Version: 0.13.0817 (Git) Branch: master Hash: 238750d3e47ccae90ce587d7b249cced30e02dfa For instance, I am working on a document and click X to close the tab. I will be prompted to save yes/no/cancel. I select cancel and the dialog appears again. The close document event is triggered twice. Another example, I launch Freecad and File-New Document twice. I will close one tab and both tabs will be removed. =========== END REPORTED IN ERROR ================== The above is no longer an issue with Fedora 16 |
Seams to be no issue. No other report and no user monitors this issue.... |
| 2012-04-04 05:04 | pperisin | New Issue | |
| 2012-04-04 05:04 | pperisin | File Added: 4.png | |
| 2012-04-04 08:35 | wmayer | Note Added: 0001884 | |
| 2012-04-04 10:23 | pperisin | Note Added: 0001885 | |
| 2012-04-04 15:57 | djreichel | Note Added: 0001887 | |
| 2012-04-04 18:56 | wmayer | Note Added: 0001888 | |
| 2012-04-22 15:46 | djreichel | Note Added: 0001959 | |
| 2012-12-20 21:59 |
Note Added: 0002725 | |
| 2012-12-20 21:59 |
Status | new => closed |
| 2012-12-20 21:59 |
Resolution | open => no change required |
