| 0000665 | FreeCAD | Bug | public | 2012-04-07 13:40 | 2012-10-01 10:45 |
| Reporter | jeanphilippe | Assigned To | |||
| Summary | 0000665: Follow up 0000640: This file crashes FreeCAD UI latest Git | ||||
| Description | Hi, While looking at this crash 640, I seem to have investigated an other issue. The information I added there where related to a crash in the UI. I pulled git, and seen the patch for 640 beeing executed (breakpoint). However, I still get the same crash in QT. " Log: Sel : Rmv Selection "pole_piece_2_baffles___linked.Pocket002.(null)" Log: QWidget::repaint: Recursive repaint detected " -> crash process: " >cd testDir >tar -xvf test.tar >gdb FreeCad (gdb) > cd testDir (gdb) > run -l pole+piece+2+baffles+-+linked.FCStd -> wait until open -> scroll Label & Attributes dock window all the way down. -> Place the cursor on the last elt ("Pocket Groove0,1,2"). -> left click to select and do not move the cursor (I have a laptop with touchpad) -> press the 'suppr' key on the keyboard (might be 'Del' on english keyboard) Program received signal SIGSEGV, Segmentation fault. QRasterPaintEngine::brushOriginChanged (this=0x8324c18) at painting/qpaintengine_raster.cpp:809 (gdb) " Thanks, JP. | ||||
| Additional Information | Note: I'm new using freecad, so I'm not completely sure I have the exact correct configuration. I ran the freecad test and they pass. So I assume it's ok. I could not add a note on the previous bug, and it seems to be a different issue so I open this new bug. ./gui/kernel/qwidget.cpp:5534 qWarning("QWidget::repaint: Recursive repaint detected"); | ||||
2012-04-07 13:40
2012-04-07 13:42
I am far from being a QT expert, so the proposed solution might not be correct but it stop the crash so I post it. Proof of concept: gibus@gibusPc:~/Dvp/FreeCad/freecad$ git diff diff --git a/src/Gui/Tree.cpp b/src/Gui/Tree.cpp index 9d19c5b..860ed6d 100644 --- a/src/Gui/Tree.cpp +++ b/src/Gui/Tree.cpp @@ -1167,7 +1167,11 @@ void DocumentObjectItem::displayStatusInfo() QString info = QString::fromAscii(Obj->getStatusString()); if ( Obj->mustExecute() == 1 ) info += QString::fromAscii(" (but must be executed)"); - getMainWindow()->statusBar()->showMessage( info ); + QMetaObject::invokeMethod(getMainWindow()->statusBar(), "showMessage", + Qt::/*Blocking*/QueuedConnection, + QGenericReturnArgument(), + Q_ARG(QString,info)); + //getMainWindow()->statusBar()->showMessage( info ); } Note: this is a proof of concept, copied from ProgressBar.cpp. I think a proper fix would be done in 2 times (as the problem might appear in different circumstance) 1 - refactor all calls to getMainWindow()->statusBar()->showMessage to be getMainWindow()->showMessage (slight behavior change(use fontMetric::elidedText before callingQStqtusBar::showMessage. would it be correct) 2 - change MainWindow::showMessage from calling 'this->statusBar()->showMessage(msg, timeout);' to use QMetaObject::invokeMethod with QueuedConnection If this is not too urgent, I would be happy to code that for you in a branch(jeanphilippe/dev) if the solution seems right to people more knowledgeable with QT. Should there be a regression test associated with it? Thanks, JP. |
Hi, I set up a github. (safer and cleaner, don't need write access to sourceforge): github.com/jeanphilippeD/FreeCAD The proposed fix are in the last 2 commits: refactor 7639bb15a1c4dc19c12c78711b5253519ab2e3ad Fix 473ba10c5e11f19e3dff9c1f47ad42a36045ab09 Note: 1 - the name of MainWindow::showMessage could be changed to 'queueStatusMsg' or something better to reflect the new usage(I could do that in a further commit) 2 - should MainWindow::statusBar() be made private or protected to avoid bad use. (the few remaining use of it would have to be redirected through MainWindow). 3 - found something strange, connect 1 slot and disconnect an other: MainWindow::addWindow connect(view, SIGNAL(message(const QString&, int)), statusBar(), SLOT(showMessage(const QString&, int))); MainWindow::removeWindow disconnect(view, SIGNAL(message(const QString&, int)), statusBar(), SLOT(message(const QString&, int ))); Also, are they needed? Hope it is helpful. Thanks, JP. |
Note on reproductibility: The main window need to be small enough for a vertical scroll bar on the tree to be there. resize main window if needed to reproduce crash. |
What Qt version do you use? To me it seems it's rather a Qt bug than a FreeCAD bug because the way how we show the information in displayStatusInfo() is OK IMO. And with Qt 4.5.3 and 4.8.4 I was not able to reproduce any crashes. |
Thanks for the answer. $ qmake --version QMake version 2.01a Using Qt version 4.8.1 in /usr/lib/i386-linux-gnu I'll upgrade to 4.8.4 when I come back from holiday next monday. Thanks, JP. |
Oops, it's not Qt 4.8.4 but also 4.8.1 and still no luck to reproduce this crash. |
2012-04-17 08:00
Hi, I'm on ubuntu 12.04 (last beta), all updated today. used the software center to install freecad 0.12.5284-dfsg-5ubuntu1 The crash still occurs. I uploaded screenShots.tar which contain screenShots of the 5 steps I took and the logFile. 2 things seem key: - the window need to be small enough so that you need to scroll. - the cursor need to be on the selected item when pressing 'suppr' (you can move the cursor away and place it back (as I did when taking screenshots)) Note: The crash do not occur on windows. The end of the log: Log: ESC[31mvoid DBusMenuExporterPrivate::addAction(QAction*, int)ESC[0m: Already tracking action "Toggle visibility" under id 218 Log: ESC[31mvoid DBusMenuExporterPrivate::addAction(QAction*, int)ESC[0m: Already tracking action "Chamfer..." under id 330 Log: Active view is pole+piece+2+baffles+-+linked : 1 Log: QWidget::repaint: Recursive repaint detected Err: Illegal storage access...Err: Thanks, JP. |
git show 58da2ebbcc94d0bb203b0ce70069abd77c2b8bab |
| 2012-04-07 13:40 | jeanphilippe | New Issue | |
| 2012-04-07 13:40 | jeanphilippe | File Added: test.tar | |
| 2012-04-07 13:42 | jeanphilippe | File Added: crashLogAndStack.tar | |
| 2012-04-07 15:45 | jeanphilippe | Note Added: 0001901 | |
| 2012-04-08 08:52 | jeanphilippe | Note Added: 0001907 | |
| 2012-04-08 16:07 | jeanphilippe | Note Added: 0001910 | |
| 2012-04-10 14:57 | wmayer | Note Added: 0001915 | |
| 2012-04-10 15:33 | jeanphilippe | Note Added: 0001920 | |
| 2012-04-12 12:03 | wmayer | Note Added: 0001932 | |
| 2012-04-17 08:00 | jeanphilippe | File Added: screenShots.tar | |
| 2012-04-17 08:13 | jeanphilippe | Note Added: 0001953 | |
| 2012-10-01 10:45 | wmayer | Note Added: 0002437 | |
| 2012-10-01 10:45 | wmayer | Status | new => closed |
| 2012-10-01 10:45 | wmayer | Resolution | open => fixed |
| 2012-10-01 10:45 | wmayer | Fixed in Version | => 0.13 |
