| 0000669 | FreeCAD | Bug | public | 2012-04-12 14:12 | 2012-04-13 09:35 |
| Reporter | jrheinlaender | Assigned To | wmayer | ||
| Summary | 0000669: Crash on opening sketch of Pad feature of PartDesign example | ||||
| Description | Using latest 0.13 version from git on Ubuntu 11.10 Start FreeCad fresh (without a .FreeCAD directory). Select "Load a PartDesign example" Open feature "Pad" Double-click on its sketch Crash on line 1803 in ViewProviderSketch.cpp Comparing Constraint.h -> enum ConstraintType with <Property name="Constraints" type="Sketcher::PropertyConstraintList"> in Document.xml of PartDesignExample.FCStd, it looks as though there is a mismatch between the enum and its integer values in the XML file. | ||||
| Additional Information | BTW, this tracker is missing Product Version 0.13 so I had to select 0.12 instead | ||||
I can confirm the crash but it is not related to the existence of the .FreeCAD folder. For any reason there is a vertical/horizontal constraint mapped to an arc which doesn't make sense. I have to check how exactly this happens... |
git show 906817f37e183ec03d15895f2369093d259eb885 It was an error in the project file because it was written with an older and buggy FreeCAD version. |
| 2012-04-12 14:12 | jrheinlaender | New Issue | |
| 2012-04-12 14:28 | wmayer | Product Version | 0.12 => 0.13 |
| 2012-04-12 15:24 | wmayer | Note Added: 0001935 | |
| 2012-04-12 15:24 | wmayer | Status | new => assigned |
| 2012-04-12 15:24 | wmayer | Assigned To | => wmayer |
| 2012-04-13 09:35 | wmayer | Note Added: 0001936 | |
| 2012-04-13 09:35 | wmayer | Status | assigned => closed |
| 2012-04-13 09:35 | wmayer | Resolution | open => fixed |
| 2012-04-13 09:35 | wmayer | Fixed in Version | => 0.13 |
