| 0000670 | FreeCAD | Bug | public | 2012-04-12 19:32 | 2012-04-17 19:54 |
| Reporter | sliptonic | Assigned To | yorik | ||
| Summary | 0000670: Draft grid only visible on first view window. | ||||
| Description | With preferences to use the grid and spacing at 1, 10. 1) start a new project and switch to draft wb. 2) Grab the wire tool and draw some lines. The grid should appear. 3) Exit the wire tool 4) menu view->create new view 5) the new view has no grid. drawing with wire tools doesn't make it appear. 6) Close both views and start a new project. 7) No grid displays when drawing. | ||||
Okay, indeed the grid only works in the first view. Will work on that... |
More generally, the grid seems to appears only in the view which was active when the grid was shown for the first time. Even if you create a new document, no grid is shown if the a Draft tool was used on the first document. FreeCAD 0.13, Libs: 0.13R0840 (Git), Fedora 16 |
Yes, that's exactly what is happening. I must find a way to bind a grid to a view and check if there is one when needed. |
Fixed with commit c01e948 |
| 2012-04-12 19:32 | sliptonic | New Issue | |
| 2012-04-13 13:05 | yorik | Note Added: 0001938 | |
| 2012-04-13 13:05 | yorik | Status | new => assigned |
| 2012-04-13 13:05 | yorik | Assigned To | => yorik |
| 2012-04-13 18:16 | galou_breizh | Note Added: 0001939 | |
| 2012-04-13 19:19 | yorik | Note Added: 0001940 | |
| 2012-04-17 19:54 | yorik | Note Added: 0001954 | |
| 2012-04-17 19:54 | yorik | Status | assigned => closed |
| 2012-04-17 19:54 | yorik | Resolution | open => fixed |
| 2012-04-17 19:54 | yorik | Fixed in Version | => 0.13 |
