| 0000674 | FreeCAD | Bug | public | 2012-04-18 10:48 | 2014-12-27 16:55 |
| Reporter | andrejburke | Assigned To | |||
| Summary | 0000674: Windows 7 hangs when FreeCad is started | ||||
| Description | I downloaded and installed FreeCAD_0.12.5284_x86_setup.msi on a 64bit version of Windows 7 running on an HP Elitebook 8540w. I have not been able to start the FreeCad application even once as it causes the entire operating to hang on startup. The main windows opens up and a progress bar at the bottom moves up to 50% at which point everything stops and the OS hangs. A reboot is required to recover. I have previously installed this same version on a 64bit version of Windows 7 running on my home PC with no problems. | ||||
Just to add, the HP has service pack 1 installed, and has 8GB of RAM. |
Most likely a graphic driver bug on your side since the 0.12 runs just fine on thousand of computers... |
Degrade to Minor because it's apparently not a FreeCAD problem but a hardware issue. |
| 2012-04-18 10:48 | andrejburke | New Issue | |
| 2012-04-18 11:45 | andrejburke | Note Added: 0001955 | |
| 2012-12-20 19:58 |
Note Added: 0002696 | |
| 2012-12-20 19:58 |
Assigned To | => Jriegel |
| 2012-12-20 19:58 |
Status | new => feedback |
| 2013-03-03 13:33 | wmayer | Note Added: 0002963 | |
| 2013-03-03 13:33 | wmayer | Severity | block => minor |
| 2014-12-27 16:55 | wmayer | Status | feedback => closed |
| 2014-12-27 16:55 | wmayer | Resolution | open => won't fix |
