| 0000678 | Draft | Feature | public | 2012-04-20 12:56 | 2013-11-13 21:30 |
| Target Version | 0.14 | ||||
| Summary | 0000678: Make decent arrows for Draft dimensions and leaders | ||||
| Description | Draft dimensions and leaders (wires with end arrow) should have an end-arrow triangle that is oriented together with the line. In order to achieve that, the arrow must be made with a real cone, not a coin markerset. | ||||
Hey Yorik, some other general thoughts. Coin Markerset is absolute rubbish and you probably know is bitmap based. For the next release, Logari and I wanted to make further improvements, and it would be good to share some of this with the rest of FreeCAD including draft. What we were also thinking was creating a set of ISO arrow heads too that could be shared under a single SoNode.This could be given information such as point, rotation and type. Overall, I think our intentions were for sketcher to create just a single scenegraph node for constraints to improve performance. The improved sphere point visual is another example where I think we can make improvements regarding point selection, https://github.com/mrlukeparry/freecad/tree/spherePointVisuals |
Oh cool! Such a node would indeed be extremely useful... And unifying visual aspect between workbenches is also something I would like a lot. And the visual stuff you did on the sketcher is the very best of freecad :) |
FreeCAD: master b3738a2f 2013-11-13 22:25:01 Details Diff |
Draft: Dimension recode - fixes 0001000, 0000852, 0000678 Draft dimensions have been recoded and should now behave better in non-XY planes, and gained several new properties to adjust their look. |
Affected Issues 0000678, 0000852, 0001000 |
| mod - src/Mod/Arch/InitGui.py | Diff File | ||
| mod - src/Mod/Draft/DraftSnap.py | Diff File | ||
| mod - src/Mod/Draft/DraftTools.py | Diff File | ||
| mod - src/Mod/Draft/DraftTrackers.py | Diff File | ||
| mod - src/Mod/Draft/DraftVecUtils.py | Diff File | ||
| mod - src/Mod/Draft/Draft_rc.py | Diff File | ||
| mod - src/Mod/Draft/InitGui.py | Diff File | ||
| mod - src/Mod/Draft/Resources/Draft.qrc | Diff File | ||
| add - src/Mod/Draft/Resources/icons/Draft_FlipDimension.svg | Diff File | ||
| mod - src/Mod/Draft/Resources/ui/userprefs-visual.ui | Diff File | ||
| mod - src/Mod/Draft/WorkingPlane.py | Diff File | ||
| 2012-04-20 12:56 | yorik | New Issue | |
| 2012-04-20 12:56 | yorik | Status | new => assigned |
| 2012-04-20 12:56 | yorik | Assigned To | => yorik |
| 2012-05-04 13:14 | yorik | Project | FreeCAD => Draft |
| 2012-08-17 18:47 | yorik | Target Version | 0.13 => trunk |
| 2012-08-18 08:47 | mrlukeparry | Note Added: 0002324 | |
| 2012-08-18 13:45 | yorik | Note Added: 0002325 | |
| 2012-08-31 11:36 | yorik | Target Version | trunk => 0.14 |
| 2013-11-13 21:30 | yorik | Changeset attached | => FreeCAD Master master b3738a2f |
| 2013-11-13 21:30 | yorik | Status | assigned => closed |
| 2013-11-13 21:30 | yorik | Resolution | open => fixed |
