| 0000680 | Draft | Bug | public | 2012-04-24 04:01 | 2012-05-22 18:11 |
| Reporter | acricfd | Assigned To | yorik | ||
| Summary | 0000680: Wrong rendering of DXF files | ||||
| Description | When DXF file is inported to latest version freecad, the lines, arcs etc.. are not correctly displayed.Some of lines and circles are displaced from their locations.This problem is not found in 0.11 Version. DXF file used for testing is attached here. | ||||
2012-04-24 04:01
I looked at your file, it renders the same in AutoCAD, FreeCAD, and LibreCAD. Is this possibly an export-to-dxf error? What program did you use to create the file? |
For me too it looks ok, same result in librecad and freecad... Please give us the options that are enabled or disabled in the Edit->preferences->Draft->Import options->Dxf screen? |
2012-05-02 07:39
2012-05-02 07:39
We have uploaded two png images (01_freecad_0.11_windows.png, 01_freecad_0.12_windows.png) to show you the difference in the display between two versions (0.11 and 0.12) of the same dxf file under windows platform. |
2012-05-02 11:37
I obtain the correct result in FreeCAD 013 (see screenshot). Probably a bug in 012 that is solved already... |
2012-05-04 12:00
sdafa.dxf imports weird on my pc (0857 git, win64). some other tools import it nicely. regards Petar |
ah indeed there seems to be a bug with solids :) It's fixed in commit c3f4871. But it's a weird way to model things with solids... They don't seem to render at all in LibreCAD. Which application was it made with? |
I made them with a PCB tool. Also, one more suggestion - when you import DXF, lines sometimes have their width defined. Can you import lines defined this way as faces created with two lines and two arcs at their ends. It is used a lot with PCB tools. The same DXF contains lines with solids. will attach picture how it looks in a PCB tool. Regards, Petar |
2012-05-07 06:30
Okay, i think I can try that, should be easy with the OCC offset... But again, it won't work for the single lines, due to that OCC limitation |
Done in commit 5c696b1. In draft DXF import references you now have a "render polyline width" option, which does what it says. Note that it will only work for polylines where the width is defined globally, not per segment. I'll close this bug report now, reopen if needed. |
| 2012-04-24 04:01 | acricfd | New Issue | |
| 2012-04-24 04:01 | acricfd | File Added: 01.dxf | |
| 2012-04-24 15:54 | jcc242 | Note Added: 0001965 | |
| 2012-04-24 16:45 | yorik | Note Added: 0001966 | |
| 2012-04-24 16:45 | yorik | Status | new => assigned |
| 2012-04-24 16:45 | yorik | Assigned To | => yorik |
| 2012-05-01 19:56 | yorik | Status | assigned => feedback |
| 2012-05-02 07:39 | acricfd | File Added: 01_freecad_0.11_windows.png | |
| 2012-05-02 07:39 | acricfd | File Added: 01_freecad_0.12_windows.png | |
| 2012-05-02 07:42 | acricfd | Note Added: 0001992 | |
| 2012-05-02 11:37 | yorik | File Added: freecad013debian.jpg | |
| 2012-05-02 11:38 | yorik | Note Added: 0001994 | |
| 2012-05-04 12:00 | pperisin | File Added: sdafa.dxf | |
| 2012-05-04 12:01 | pperisin | Note Added: 0002008 | |
| 2012-05-04 12:46 | yorik | Note Added: 0002009 | |
| 2012-05-04 13:14 | yorik | Project | FreeCAD => Draft |
| 2012-05-07 06:28 | pperisin | Note Added: 0002024 | |
| 2012-05-07 06:30 | pperisin | File Added: LinesWithWidth.png | |
| 2012-05-07 12:24 | yorik | Note Added: 0002028 | |
| 2012-05-16 22:41 | yorik | Status | feedback => assigned |
| 2012-05-22 18:11 | yorik | Note Added: 0002073 | |
| 2012-05-22 18:11 | yorik | Status | assigned => closed |
| 2012-05-22 18:11 | yorik | Resolution | open => fixed |
| 2012-05-22 18:11 | yorik | Fixed in Version | => 0.13 |
