| 0000684 | FreeCAD | Feature | public | 2012-04-26 19:26 | 2012-06-16 12:32 |
| Reporter | shoogen | Assigned To | |||
| Summary | 0000684: Add an option that make FreeCAD check the shape after each boolean/loft operation | ||||
| Description | OpenCASCADE often returns invalid Shapes that currupt the feature tree. If that happens FreeCAD should show a sign (like the exclamation mark in a red circle) in the TreeView, that will notify the user of a problem. this would be an improvement over silently returning a broken shape. Since shape.check() and shape.isValid() are expensive in compuation time this behavior should be switchable in the program preferences. | ||||
This is only meant for recaculating Features. Not for calls from the Python. |
Since the exclamation mark is used when exceptions are caught, maybe a new symbol for the case of a invalid shape or a 'null' shape has to be considered. |
Actually if I'm not mistaken, the current exclamation mark appears when the view provider is unable to build its output. In the case of shape-based objects, it should appear when the shape is not valid, no? Or you can have a bad shape that produces a valid coin output anyway? We should make some tests... |
I tried to implement this feature but i got stuck with a SIGSEGV 0x00007fffd0b09d75 in TopExp_Explorer::Init(TopoDS_Shape const&, TopAbs_ShapeEnum, TopAbs_ShapeEnum) () from /usr/lib/libTKBRep-6.3.0.so |
Does it crash inside BRepCheck_Analyzer? And does it crash for all cases? |
I missed a call path. When the broken shape created by a previous fusion reached another boolean it crashed OCC. That problem does not appear if the new feture is enabled. git://github.com/5263/FreeCAD.git review-feat684-check-shape-after-boolean simple testfile would be 'fan2' (http://forum.freecadweb.org/viewtopic.php?f=10&t=2389&start=50#p20037) |
would anybody mind reviewing the patch? |
I think Werner can review this much better than me, but if needed I can have a look too, just ask. |
Reviewed and merged into master |
| 2012-04-26 19:26 | shoogen | New Issue | |
| 2012-04-26 19:28 | shoogen | Note Added: 0001971 | |
| 2012-04-26 19:32 | shoogen | Note Added: 0001972 | |
| 2012-04-27 11:11 | yorik | Note Added: 0001973 | |
| 2012-06-07 17:05 | shoogen | Note Added: 0002146 | |
| 2012-06-07 18:26 | wmayer | Note Added: 0002148 | |
| 2012-06-07 21:59 | shoogen | Note Added: 0002152 | |
| 2012-06-07 22:17 | shoogen | Note Edited: 0002152 | |
| 2012-06-07 23:04 | shoogen | Note Edited: 0002152 | |
| 2012-06-07 23:05 | shoogen | Note Edited: 0002146 | |
| 2012-06-15 06:39 | shoogen | Note Added: 0002202 | |
| 2012-06-15 06:40 | shoogen | Note Edited: 0002152 | |
| 2012-06-15 11:27 | yorik | Note Added: 0002207 | |
| 2012-06-16 12:32 | wmayer | Note Added: 0002212 | |
| 2012-06-16 12:32 | wmayer | Status | new => closed |
| 2012-06-16 12:32 | wmayer | Resolution | open => fixed |
| 2012-06-16 12:32 | wmayer | Fixed in Version | => 0.13 |
