| 0000698 | FreeCAD | Feature | public | 2012-05-07 06:36 | 2012-05-11 17:36 |
| Summary | 0000698: Draft Extrude suggestions | ||||
| Description | Hi, I use a lot Draft Extrude feature. Here is two small sugestions for it. 1 - Switch current behavior so that extrude goes along face normal by default (currently you need to press CTRL to do this). This was discussed before on forum. 2 - make non planar faces extrude in a way so that each point from a face extrudes along it's face normal. Have a look at the picture "extrude". If I extrude this selected face, I'd like to get this resulting shape. Regards, Petar | ||||
2012-05-07 06:36
okay point 1 makes sense, but point 2 is a huge and complex work to do, and I think beyond the scope of the Draft module... So I think I'll do point 1, but point 2 should be the subject of another, more advanced and more generic feature, maybe in PartDesign... |
Done in ba17ed0 |
| 2012-05-07 06:36 | pperisin | New Issue | |
| 2012-05-07 06:36 | pperisin | File Added: extrude.png | |
| 2012-05-10 14:18 | yorik | Note Added: 0002033 | |
| 2012-05-10 14:19 | yorik | Status | new => assigned |
| 2012-05-10 14:19 | yorik | Assigned To | => yorik |
| 2012-05-11 17:36 | yorik | Note Added: 0002034 | |
| 2012-05-11 17:36 | yorik | Status | assigned => closed |
| 2012-05-11 17:36 | yorik | Resolution | open => fixed |
| 2012-05-11 17:36 | yorik | Fixed in Version | => 0.13 |
