| 0000708 | File formats | public | 2012-05-18 01:09 | 2012-05-28 15:41 | |
| Reporter | scaprile | Assigned To | yorik | ||
| Summary | 0000708: incorrect dxf export | ||||
| Description | cilinder orientation seems to cause problems see attached files | ||||
2012-05-18 01:09
Actually the DXF exporter is not really made to export 3D objects yet. You might have better luck trying to export the Drawing page instead of the 3D object, but keep in mind all this is still work-in-progress... |
Closing now as it won't get "fixed" in the current state of the exporter. In the future we might extend it to support some form of 3D export (not easy with available free DXF 3D abilities)... |
| 2012-05-18 01:09 | scaprile | New Issue | |
| 2012-05-18 01:09 | scaprile | File Added: dxf.zip | |
| 2012-05-18 17:31 | yorik | Status | new => assigned |
| 2012-05-18 17:31 | yorik | Assigned To | => yorik |
| 2012-05-18 17:52 | yorik | Note Added: 0002061 | |
| 2012-05-28 15:41 | yorik | Note Added: 0002095 | |
| 2012-05-28 15:41 | yorik | Status | assigned => closed |
| 2012-05-28 15:41 | yorik | Resolution | open => won't fix |
