| 0000715 | Draft | Bug | public | 2012-05-21 07:53 | 2012-08-14 21:40 |
| Target Version | 0.13 | Fixed in Version | 0.13 | ||
| Summary | 0000715: Draft move does not respect working plane | ||||
| Description | Hi, I was trying to move objects on an XY plane, and the best way to do this would be to use Draft move. However, it seems that draft rotate respects working plane, and draft move does not Can this be fixed | ||||
| Additional Information | Win7 latest win unstable 0.13 | ||||
It seems to me that moving along the working plane works fine... Can you give me an exact step-by-step method to reproduce the problem please? |
Create box. set working plane to be one of it's faces move box - it will move in space, and will not respect working plane. maybe I am doing something wrong. I select working plane by clicking the loooong button in draft command bar, and after that click on a face on a box. |
0943 0.13 |
http://dl.dropbox.com/u/36707971/Video_1337621878.wmv |
Ah I see now... the move actually respects the working plane, the second point is on the working plane. I'm not sure what's the best way to do here: either move the working plane up to the first point you click, or, instead of snapping a vertex, snap the corresponding point on the WP... I must think a bit what's the best path. In the meantime, have you tried pressing shift? it might be the best way to do what you want |
1 - shift does not help - he moves in a weird way, but just on one line. I would expect that if I set some working plane, and do move by selecting object, clicking on toolbar icon and then on one point - move would be done in a way that selected point would remain on a plane that is parallel to working plane and intersects point's original location. in the video, I would expect that bottom side of a box remains on a plane under it. Hope it makes sense. |
It does, but I can imagine other cases when someone would want the contrary, snap any selected point in space to a working plane position. I must find a way that satisfies it all.. The actual (right?) way to do this would be to set the WP to the upper face of your cube.. you can do that by selecting the face then pressing the WP button |
1 - I think it is done other way around - click WP button and then select face. Please correct if I am wrong. 2 - If I am not wrong, I do that in a video, and it does not work. |
Ah indeed this looks to be broken, I'll fix that too |
one more suggestion: If user presses X, Y or Z, allow him to move only in those directions. Maye the best to make this would be to make X, Y and Z in the draft command bar buttons - they toggle on pressing X, Y and/or Z, and if they are off, that dimension is not used to move object. |
Ah excellent idea... This would liberate totally the shift key... |
Done with 2efc491. You can now press X, Y and Z to constrain/unconstrain to a specifc axis. Shift still works, but will probably be disabled in the future. Draft move now also respects the working plane, provided you set it correctly before the movement. |
I have just tested - it works nicely, but I have some feedback: 1 - I like how now icons are available even when nothing is selected. However, when I want to move a box (when nothing is selected), I first press move command in draft and then I have to click on a box twice (not double click, but twice single click) in order for it to move - can this be made so that I only click once on a box to move it. 2 - you implemented X, Y, and Z constraining of axis in a way that when user presses X, he is moving only on X axis. This way you disable two axis (Y and Z). This is cool, but what if user wants to move on a plane - so to disable only one axis - I would recommend "Shift+X" for disable move on X axis only (and allow move on YZ plane) 3 - I'm having problems in moving box on a Z axis - X and Y work, but Z does not want to work somehow (move and press z - does not want to do anything). 4 - move on a working plane works like a charm. Great job. Regards, Petar |
Ok, it seems that X and Y are moving box horizontally and vertically on screen - so not on X and Y axis in 3D, but on X and Y axis on screen. Z does nothing. |
Z problem is fixed with commit 969f4b5 |
| 2012-05-21 07:53 | pperisin | New Issue | |
| 2012-05-21 11:58 | yorik | Note Added: 0002063 | |
| 2012-05-21 13:34 | pperisin | Note Added: 0002064 | |
| 2012-05-21 13:35 | pperisin | Note Added: 0002065 | |
| 2012-05-21 13:40 | pperisin | Note Added: 0002066 | |
| 2012-05-21 17:48 | yorik | Note Added: 0002068 | |
| 2012-05-21 17:55 | pperisin | Note Added: 0002069 | |
| 2012-05-21 18:29 | yorik | Note Added: 0002070 | |
| 2012-05-21 18:29 | yorik | Status | new => assigned |
| 2012-05-21 18:29 | yorik | Assigned To | => yorik |
| 2012-05-21 18:55 | pperisin | Note Added: 0002071 | |
| 2012-05-21 18:55 | pperisin | Note Edited: 0002071 | |
| 2012-05-21 19:32 | yorik | Note Added: 0002072 | |
| 2012-05-29 12:24 | pperisin | Note Added: 0002100 | |
| 2012-05-29 16:53 | yorik | Note Added: 0002101 | |
| 2012-06-11 15:34 | yorik | Note Added: 0002179 | |
| 2012-06-11 15:34 | yorik | Status | assigned => closed |
| 2012-06-11 15:34 | yorik | Resolution | open => fixed |
| 2012-06-11 15:34 | yorik | Fixed in Version | => 0.13 |
| 2012-06-11 19:34 | pperisin | Note Added: 0002186 | |
| 2012-06-11 19:34 | pperisin | Status | closed => feedback |
| 2012-06-11 19:34 | pperisin | Resolution | fixed => reopened |
| 2012-06-11 20:04 | pperisin | Note Added: 0002187 | |
| 2012-06-12 16:50 | yorik | Status | feedback => assigned |
| 2012-06-12 16:53 | yorik | Project | FreeCAD => Draft |
| 2012-06-12 16:54 | yorik | Target Version | => 0.13 |
| 2012-08-14 21:39 | yorik | Note Added: 0002321 | |
| 2012-08-14 21:40 | yorik | Status | assigned => closed |
| 2012-08-14 21:40 | yorik | Resolution | reopened => fixed |
