| 0000721 | Sketcher | Bug | public | 2012-05-23 19:34 | 2012-11-14 22:25 |
| Reporter | bulled001 | Assigned To | |||
| Summary | 0000721: massive memory leak when dragging an unconstained model | ||||
| Description | Windows 7 64 bit running the 32bit version the program consumes memory as you drag the unconstrained sketch around. Lots of memory 6mbytes for just dragging the model from side to side a bit. In fact I just noticed that just dragging the mouse around the screen causes memory to be lost(accoroding to task manager) | ||||
2012-05-23 19:34
It's easy to reproduce: Create a sketch with a single line Move the line on one end point over the screen => You won't see a memory allocation Now set a lock constraint on an end point Move the free point of the line => You will see an immense allocation of memory |
It very likely happens when rendering the constraint elements in the 3d view when in edit mode: If you comment out the line Gui.activeDocument().setEdit('Sketch') from the code below you'll note a much less memory usage. App.activeDocument().addObject('Sketcher::SketchObject','Sketch') App.activeDocument().Sketch.Placement = App.Placement(App.Vector(0.000000,0.000000,0.000000),App.Rotation(0.000000,0.000000,0.000000,1.000000)) Gui.activeDocument().activeView().setCamera('#Inventor V2.1 ascii \n OrthographicCamera {\n viewportMapping ADJUST_CAMERA \n position 0 0 87 \n orientation 0 0 1 0 \n nearDistance -112.88701 \n farDistance 287.28702 \n aspectRatio 1 \n focalDistance 87 \n height 143.52005 }') Gui.activeDocument().setEdit('Sketch') App.ActiveDocument.Sketch.addGeometry(Part.Line(App.Vector(-120.701385,3.407310,0),App.Vector(-56.891762,44.501541,0))) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(-79.194153,39.958462,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(-77.748627,40.164959,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(-71.140503,39.338947,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(-64.325890,39.338947,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(-57.717773,39.338947,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(-50.077133,39.338947,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(4.646339,47.392590,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('DistanceX',0,1,-120.701385)) App.ActiveDocument.Sketch.addConstraint(Sketcher.Constraint('DistanceY',0,1,3.407310)) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.917882,47.186085,0),0) App.ActiveDocument.recompute() App.ActiveDocument.Sketch.movePoint(0,2,App.Vector(6.298359,48.012104,0),0) App.ActiveDocument.recompute() |
It's related somehow to SoDatumLabel |
Problem found: It's a (useless) call of glGenTextures and glBindTexture without a glDeleteTextures |
git show 09866ae |
| 2012-05-23 19:34 | bulled001 | New Issue | |
| 2012-05-23 19:34 | bulled001 | File Added: test.FCStd | |
| 2012-11-14 13:17 | wmayer | Status | new => confirmed |
| 2012-11-14 13:44 | wmayer | Note Added: 0002516 | |
| 2012-11-14 13:56 | wmayer | Note Added: 0002517 | |
| 2012-11-14 16:11 | wmayer | Note Added: 0002518 | |
| 2012-11-14 22:04 | wmayer | Note Added: 0002521 | |
| 2012-11-14 22:25 | wmayer | Note Added: 0002522 | |
| 2012-11-14 22:25 | wmayer | Status | confirmed => closed |
| 2012-11-14 22:25 | wmayer | Resolution | open => fixed |
| 2012-11-14 22:25 | wmayer | Fixed in Version | => 0.13 |
