| 0000073 | FreeCAD | Feature | public | 2010-02-10 09:47 | 2010-02-10 19:58 |
| Reporter | unauthenticated | Assigned To | wmayer | ||
| Product Version | 0.9 | ||||
| Summary | 0000073: Problem building on 64Bit Ubuntu Karmic. | ||||
| Description | I ran script as recommended got following error during make: /home/tim/downloads/freecad/src/Base/Stream.cpp: In member function ‘virtual int Base::IODeviceIStreambuf::underflow()’: /home/tim/aerodevices/downloads/freecad/src/Base/Stream.cpp:269: error: ‘std::memcpy’ has not been declared make[2]: *** [src/Base/CMakeFiles/FreeCADBase.dir/Stream.cpp.o] Error 1 make[1]: *** [src/Base/CMakeFiles/FreeCADBase.dir/all] Error 2 make: *** [all] Error 2 | ||||
Ok, I fixed the missing prototype problem by adding #include <cstring> in the #ifdef __GNUC__ section of the Stream.cpp file Hope this helps. |
| 2010-02-10 09:47 | unauthenticated | New Issue | |
| 2010-02-10 10:25 | unauthenticated | Note Added: 0000174 | |
| 2010-02-10 19:58 | wmayer | Assigned To | => wmayer |
| 2010-02-10 19:58 | wmayer | Status | new => closed |
| 2010-02-10 19:58 | wmayer | Resolution | open => fixed |
