| 0000732 | FreeCAD | Bug | public | 2012-06-03 11:08 | 2012-06-03 12:41 |
| Reporter | franzengel | Assigned To | |||
| Summary | 0000732: Problem with sketch when using different "Navigationsstil" | ||||
| Description | When I use the Navigationstil "Inventor Naviagtion" I can't draw in the sketchmode, because I rotate the picture with the same mouse button I use for make new points. | ||||
With Inventor navigation this is normal behaviour. To draw in the sketch mode you have to press the Ctrl key. Note: The Inventor mode is quite nice when you rotate and pan a lot but for productive work the other styles CAD or Blender might be better for you. |
| 2012-06-03 11:08 | franzengel | New Issue | |
| 2012-06-03 12:41 | wmayer | Note Added: 0002113 | |
| 2012-06-03 12:41 | wmayer | Status | new => closed |
| 2012-06-03 12:41 | wmayer | Resolution | open => no change required |
| 2012-06-03 12:41 | wmayer | Fixed in Version | => 0.13 |
