| 0000733 | FreeCAD | Feature | public | 2012-06-04 00:50 | 2012-06-08 16:56 |
| Reporter | jrheinlaender | Assigned To | |||
| Summary | 0000733: Up to first/last/face, two-sided dimension options for Pad Feature | ||||
| Description | This will add the following options to the Pad feature: 1. Extrude up to the first face found 2. Extrude up to the last face found 3. Extrude up to an arbitrary face the user chooses 4. Enter a second dimension to extrude in the other direction | ||||
| Additional Information | See git@github.com:jrheinlaender/FreeCAD.git branch jrheinlaender/PartDesign There is also a demo part in there | ||||
I have checked out your branch but it doesn't work for me. In your code I have found lines like Type.getValueAsString() == "TwoLengths". Note, the return value of getValueAsString() is a const char* not std::string and thus you mustn't use the == operator. The easiest is to std::string padType = Type.getValueAsString(); padType == "TwoLengths" I'll fix it on my local branch from your branch and merge everything into master later. |
2012-06-08 09:14
Attached as a patch which fixes build errors on Windows and fixes the above issues. I tried to rebase your branch to my master but I completely failed. I got dozens of merge conflicts and when trying to fix them git still complained about some of them. So, I gave up! |
Yes, I had the same problems with the rebase, see http://forum.freecadweb.org/posting.php?mode=reply&f=10&t=2656#pr20127 I think I will just delete everything and start over again with git... |
This part is included now. |
| 2012-06-04 00:50 | jrheinlaender | New Issue | |
| 2012-06-08 07:13 | wmayer | Note Added: 0002153 | |
| 2012-06-08 09:14 | wmayer | File Added: partdesign.patch | |
| 2012-06-08 09:18 | wmayer | Note Added: 0002154 | |
| 2012-06-08 11:04 | jrheinlaender | Note Added: 0002155 | |
| 2012-06-08 16:56 | wmayer | Note Added: 0002158 | |
| 2012-06-08 16:56 | wmayer | Status | new => closed |
| 2012-06-08 16:56 | wmayer | Resolution | open => fixed |
| 2012-06-08 16:56 | wmayer | Fixed in Version | => 0.13 |
